09-08-2022 06:36
09-08-2022 06:36
https://twitter.com/Mell1960/status/1567811488873684992
Does anyone know that clock face this is? I have tried searching it with "Kay" and I just can't find it. I have it on my clock face now but am trying to share it with a friend. Hoping someone knows. Thanks for your help!
09-08-2022 12:24
09-08-2022 12:24
😂 No worries @mell1960
Heres how it’s done locate and click the "Choose as Best Answer" button within the helpful post to mark it as an answer.
08:40
07:06
09-08-2022
08:40
07:06
Hello @mell1960
It can be found in the Fitbit App Gallery. Just type it in as you see it kay.clock.step.2 in the search bar.
Just open your Fitbit App, Tap your profile picture, scroll down and tap Versa 2 then tap Gallery. Next tap the magnifying glass at the top of your screen then type kay.clock.step.2 into the search bar.
‘More details can be found here: https://gallery.fitbit.com/details/bc09fcf5-b08d-4542-b028-31ba5d59f50e
😃I hope this provides you with the best answer to your question. Please let me know
09-08-2022 08:44
09-08-2022 08:44
08:50
07:07
09-08-2022
08:50
07:07
Hello again @mell1960
Do you have the latest Fitbit App version? I have Versa 2 as well and it appears in my Gallery.
Try to copy paste this “ kay.clock.step.2 ‘ directly into your search in the gallery.
Here’s a screenshot of my Gallery
09-08-2022 09:02
09-08-2022 09:02
Best Answer09-08-2022 09:09 - edited 09-08-2022 09:13
@mell1960 try logging out of the Fitbit app, restart your phone then log back into the Fitbit App. Remember to tap search or enter on your keypad once you type in kay.clock.step.2 in the search bar
Android latest version is 3.66 and iOS is 3.66
09-08-2022 09:21
09-08-2022 09:21
09-08-2022 09:31
09-08-2022 09:37
09-08-2022 09:38
09-08-2022 09:55
09-08-2022 09:55
Best Answer09-08-2022 10:26
09-08-2022 10:26
09-08-2022 11:15
09-08-2022 11:15
Best Answer09-08-2022 11:18
09-08-2022 11:30
09-08-2022 11:30
Best Answer09-08-2022 11:35
09-08-2022 11:35
@mell1960- don't understand. Here is the link to it that @SunsetRunner kindly provided
No looking is necessary, just click the link in your phone browser and click OPEN APP and install it.
Best Answer09-08-2022 11:38
09-08-2022 11:38
Is your friend using this path to locate it:
Open your Fitbit App, tap your profile picture, scroll down and tap Versa 2 then tap Gallery. Next tap the magnifying glass at the top of your screen then type kay.clock.step.2 into the search bar. You need to type it in exactly the way you see it. To include the dots with no space between them.
09-08-2022 11:50
09-08-2022 11:50
09-08-2022 11:53
09-08-2022 11:55
09-08-2022 11:55
That’s awesome news @mell1960! 😃 I’m happy it finally worked and I’m happy your friend will be able to share in using the clock face as well. Please consider marking either my response that helped or @Guy_ ‘s respond that helped as “Best Answer”. Doing so will help others who might seek the same clock face (or help finding one) faster. I’d appreciate it. Enjoy the rest of your day and as always Happy Stepping!
