09-27-2022 20:51 - edited 09-28-2022 15:40
Does fitbit versa 2 have a feature to prevent overcharging or not, if it doesn't have I HIGHLY recommend fitbit to make it in the next update
Additional details:
Fitbit versa 2 firmware version: 35.72.1.23
Android version: 12
Moderator Edit: Clarified subject (you didn't clarify the subject)
09-28-2022 15:43
09-28-2022 15:43
I've contacted fitbit customer support and they said they don't have it (overcharge protection)
However I made a feature request which I highly recommend you to vote/put a like on cuz it will help all fitbit users or people that use versa series, https://community.fitbit.com/t5/Feature-Suggestions/Overcharge-Protection-on-versa-series/idi-p/5247...
09-28-2022 06:05 - edited 10-09-2024 09:01
Hi there, @SunsetRunner. Thanks for stopping by in the Community Forums.
Please note there is not such an app. Nevertheless, while the watch charges, tap the screen twice to check the battery level. Tap again to use it while it charges. For more information, see How do I charge my Fitbit device?
Thanks for your suggestion. We're constantly striving to improve Fitbit products and services, and we appreciate all of the input we receive from our customers. The best place to make your voice heard is the Feature Suggestion board on our community.
If a similar suggestion has already been made by another member of the community, you can vote for their suggestion and add your comments.
Thanks for your feedback and for participating in our community!
Best Answer09-28-2022 11:43
09-28-2022 11:43
I didn't mention if a app can do it, I said Does fitbit (this company) have a feature ti prevent overcharging also by accident i marked your message as best answer
Best Answer09-28-2022 15:20 - edited 09-29-2022 03:00
@SunsetRunner There is a way you can do this. If you tap on the three dots in the upper right of that incorrect post, you should get a "Not the Best Answer" option, because you posted the original question. But I can do that for you.
Fitbit doesn't specify in any of its manuals or other device information if it has any way to keep a battery from overcharging
Laurie | Maryland
Best Answer09-28-2022 15:43
09-28-2022 15:43
