Does the Fitbit Versa synchronize with Huawei Mate 10 pro?
Hello
I would like to buy the new Fitbit Versa but I want to know first if it does work and synchronize on my Huawei Mate 10 pro phone via the Fitbit app.
If not, when will this problem be fixed?
Thanks a lot
4 REPLIES 4
It doesn't appear to be on the supported devices list, although it seems many devices not on the list still work fine. I guess the only way to know for sure is for someone to test it.
If you buy direct from Fitbit you will at least have the 45 day satisfaction guarantee if you decide to try it and it doesn't work.
Community Council Member
Nathan | UK
Looking to get more sleep? Join the conversation on the Sleep better forum.
I am able to get texts and calendar notifications.  Not working with email.   It took a while to get it to work.  Changing notification settings in the Fitbit app and a couple phone reboots.  But seems to be working fine now.
My ZTE Axon 7 is not on the list, but works flawlessly with my Versa.
Hi, you are lucky. My mate 10 pro doesn't sync with versa, even versa couldn't connect with phone during workouts to use gps
