Does the heart rate monitor not read through tattoos
I have a sleeve and the heart rate monitor and the sleep tracking don't work. Is it because of my tattoos???
2 REPLIES 2
Hmm that's very possible, tattoo ink is metal and the higher the saturation of ink makes it harder for the optical sensors to see through your skin. This may sound a bit batty but you could try putting the fitbit on your ankle or any other area that doesn't have a tattoo just to test? Also do you get an HR reading while awake? I am also suspecting it could be a hardware/software issue. If your Fitbit is new then give it time to read info for a couple of days.
Heart rate uses the Green light, the Oxygen sensor uses both Red and Infrared light.
