12-05-2018 05:40
12-05-2018 05:40
Hi;
I am using Galaxy A5 and could not get phone call and message notifications.
Whenever someone calls me I would like to see it through my Versa and I should be able to answer it.
My phone's bluetooh is always on and is it enough to see phone calls on my fitbit screen?
Best
Ali kemal Ağırman
12-05-2018 06:18 - edited 12-05-2018 07:18
To find out whether fitbit supports your device, go to: https://www.fitbit.com/devices and type in the empty field your device. Kindest regards kuzibri
12-05-2018 07:21
12-05-2018 07:21
12-05-2018 07:27
12-05-2018 07:27
I just searched the supported devices and it's says that the A5 is not supported. Nevertheless, this means not that your Versa wouldn,t work. Go to settings on your Versa, scroll down to notifications and turn them on. You also have the choice to only turn them on during daytime and off during night. Answering a call via your Versa is not possible. Kindest regards, kuzibri
12-05-2018 07:31
12-05-2018 07:31
12-05-2018 07:48
12-05-2018 07:48
I do not know if you can see that someone is calling simultenously. Which features of the Versa you can use with your phone? I would answer to that: go to the Fitbit app on your phone and customize it to your personal needs. You can add apps, change clock faces, etc etc. Kindest regards kuzibri
12-05-2018 09:41 - edited 12-06-2018 06:35
I have the galaxy S5 I am getting call notifications but cannot send quick replys, also see text notifications but cannot read or reply, any suggestions on settings?
