Don't swim with Versa 2
My versa 2 died after splashing in wadding pool. So upset! Watch lasted only 1.5 years. What a waste of money :money_bag: :money_with_wings: Support was no help either 😕
3 REPLIES 3
Hi @Awezome1  what did support suggest? I know from reading these forums that often putting a Fitbit into a dry bowl of rice for 48 hours before charging it has helped. After the rice, clean all contact points and charge it up. Guess you already tried that?
Stepping in the U.S.A. since September 2013. Android 14
They suggested I try turning it on, then charging it over night. Then they offered me a discount on a new one. Yes,
I tried the rice thing, and cleaned all points with rubbing alcohol...
Sounds like you did all you could @Awezome1 . If you do get a new Fitbit, just add it as a new device on your existing account so your steps continue.
