07-06-2018 00:00
07-06-2018 00:00
Amonth ago Fitbit said I Burnet about 23000 calories a week.. Wich seems accurate.. how ever now it says I burn the double!! 49000 a week?! What has changed?? Is it me that have changed some settings??
 Best Answer07-06-2018 00:03
                              07-06-2018 00:03
This can be caused, as you suggest, by a change in your profile settings. In particular, your weight, age, and height has a direct affect on the calorie calculations. Have you checked yours at: https://www.fitbit.com/user/profile/edit ?
If they look ok, do you have any links to external apps that may be causing a problem e.g. MyFitnessPal?
07-06-2018 00:03
                              07-06-2018 00:03
07-06-2018 01:52
07-06-2018 01:52
