09-20-2019 08:09
09-20-2019 08:09
I just downloaded the latest firmware version for my Versa. Now my test notifications are not working but the calls notifications are working.
Any suggestions. I checked all the app settings and they are all on.
TIA
09-20-2019 08:11
09-20-2019 08:11
Having the same issue! I was just going to put out feelers but I'm glad to see that it's not just me. Putting this out there so they know there are more of us with this issue.
Best Answer09-20-2019 08:11
09-20-2019 08:11
Same here 😞
Best Answer09-20-2019 08:17
09-20-2019 08:17
Best Answer09-20-2019 08:20
09-20-2019 08:20
I spotted on another topic in this forum that it might be worth un-installing and then re-installing the FitBit app on your phone and then re-doing all the permissions as part of the re-install.
Best Answer09-20-2019 08:26
09-20-2019 08:26
Is it working after the reinstallation
Best Answer09-20-2019 08:36
09-20-2019 08:36
I've done that twice this morning...no luck.
09-20-2019 08:57
09-20-2019 08:57
I tried that as well. it seems that people that were having luck with that were android users and i'm apple 😞
Best Answer09-20-2019 09:19
09-20-2019 09:19
I'm android...Samsung s10+. No luck here.
Best Answer09-20-2019 09:26
09-20-2019 09:26
xiomi 5pro
Best Answer09-20-2019 09:45
09-20-2019 09:45
Having the same problem
Best Answer09-20-2019 20:03
09-20-2019 20:03
I'm Android, and a reinstall worked for me.
Best Answer09-20-2019 20:07
09-20-2019 20:07
Just found out that it is an ios issue that Fitbit is working on. I'm wondering if it has to do with the new 13.0 update. Hope it can be fixed soon!
Best Answer09-20-2019 20:51
09-20-2019 20:51
