Dumb band question
ANSWERED
Are there supposed to be two band sets (small and large)? My Versa came with bands attached and there is only one extra band marked as L. Am I missing the other L band?
The box shows two complete sets.
1 BEST ANSWER
Accepted Solutions
It comes with 2 sizes, small and large. But the way they have it is the top part of the watch (the buckle) is one piece and for the small or large size you chose the length of the band, the one marked “s” or “l”. Hope that makes sense. To see if I can clarify what I’m saying...you only switch out the length part of the band and the buckle part stays on.
3 REPLIES 3
Hello @Kimbernada
Each Versa comes with one small and one large band. You can always check the user manual to see what comes in the box. I checked the store and it states that you get two bands. My Flex was the same, where I received one small and one large band.
Keep on stepping!
Stepping in the U.S.A. since September 2013. Android 14
Ah. .. Got it! Thank you!!
