If I do a Fitbit coach workout using my Versa the app records two workouts. As you can see, they’re not identical - the Coach one appears the match the time and length of the workout, whereas the Fitstar one shows the same calories burned as the screen on my watch, so I am at a loss as to which one is the ‘real’ one. This seems to be an ongoing issue for people - when you are trying to track calories in and out it’s not ideal!
Best Answer@SarahHes Whatever matches your watch is the correct one. Fitbit Coach provides you with a "guesstimate", Versa with actual estimation based on your HR data. I agree, it should not record two workouts, though I doubt you get credited double calories as the time periods of the workouts overlap. It is very confusing though. Can you please post this suggestion to Fitbit's Feature Suggestions Forum to bring it to the attention of moderators and other users? Thank you!
Best AnswerYes, please post this in the suggestion forum with your pic! I've tried revoking permissions from Fitstar, reconnected the Fitbit Coach app to the Fitbit app and it's still listed as its old name in my permissions as seen here. I think this should be fixed so that I can actually see my workouts without being bombarded with dupes between Fitbit Coach and Fitstar.
