04-17-2018 14:48
04-17-2018 14:48
When they decided which options to include in the versa's exercise app did they do away with the elliptical option? That's about the only one I use, it's a bummer if they got rid of it.
04-17-2018 14:52
04-17-2018 14:52
Hmmm... I have the elliptical option on my Versa. I had to manually add it on as an exercise shortcut, though.
04-17-2018 14:55
04-17-2018 14:56
04-17-2018 14:56
I was trying to figure out how to do that, is it fairly simple? I can't seem to find out how to edit the list
04-17-2018 15:36
04-17-2018 15:36
Take a look at the link below for the steps on how to customize exercise.
04-28-2018 10:14
04-28-2018 10:14
Hi!
So was wondering the same thing. I went into settings, clicked on exercise shortcuts, and deleted the ones I did not use by swiping left. It will then allow you to add others. Good luck!
04-28-2018 10:15
04-28-2018 10:15
08-22-2018 05:41
08-22-2018 05:41
Good Morning. I was able to go into settings (from my laptop) and add elliptical. Thanks for the help! How long does it take for it to update on my watch?
04-21-2019 06:44
04-21-2019 06:44
They’ve essentially created a preset of 7 other exercises. If you swipe from right to left (in the app), you can remove an excercise thus creating an “open space” — in the top right-hand corner of the app a ‘+’ pops up. Click on it and select your exercise of choice! Fitbit on!
06-18-2020 05:40
06-18-2020 05:40
How did you manually add the elliptical exercise
I have a versa lite
