Encryption turned on and wont turn off
Encryption turned on and wont turn off.
Ever since it turned on my Versa 2 Isn't getting notifications sent to it
8 REPLIES 8
Hi @jadelia94 - could you give a bit more information about what you mean by encryption and where you are accessing it.
The notification part of fibit the encryption turned on and it won't turn off and the notification aren't going to my fibit
@jadelia94-  it is probably normal that it is on. This is most likely not the reason for not getting notifications
Try pull down the from the top edge of the watch once, and then again and click on the 2 white bars to get to Quick Settings and make sure that neither Sleep or Do not disturb are enabled.
They aren't enabled I have never had this problem before
@jadelia94- try logout of the Fitbit app and restart both watch and phone, there may be a syncing problem.
Just tried that. Still not getting notifications
I did nothing changed
@jadelia94 - you can chat via the Fitbit App, click profile photo, Help & support, Contact Customer support, they might be able to help.
