12-17-2019 10:27
12-17-2019 10:27
Why is this now available on only some Charge 3 and Versas?
07-27-2020 07:22
07-27-2020 07:22
07-28-2020 00:16
07-28-2020 00:16
Best Answer07-28-2020 00:52
07-28-2020 00:52
07-31-2020 21:39
07-31-2020 21:39
I don’t think my red light works this is a new Charge 3 what should i do?
Best Answer08-01-2020 05:50
08-01-2020 05:50
I never had any information in the graph, it was just blank and now the graph is completely gone. Such a strange thing.
Best Answer08-01-2020 13:07
08-01-2020 13:07
Best Answer01-19-2021 15:15
01-19-2021 15:15
My graph has stopped tracking the oxygen variations- it worked before now just has a flat line. Nothing has changed for me, still wearing it the same way. Any ideas?
01-19-2021 17:42
01-19-2021 17:42
Best Answer01-19-2021 23:14
01-19-2021 23:14
It happened several times with me, last 10 months. First try with restart, then with Remove/Add fitbit device in app profile. Works always.
Best Answer01-20-2021 02:27
01-20-2021 02:27
Hello can you please explain what it means if there are high variations of blood oxygen shown on the graph?
Best Answer01-20-2021 02:50
01-20-2021 02:50
I downloaded the spo watch face works perfectly during night time while sleeping
Best Answer01-20-2021 05:20
01-20-2021 05:20
Best Answer01-21-2021 00:30
01-21-2021 00:30
Best Answer02-21-2021 21:02
02-21-2021 21:02
Not sure how to interpret this. Please explain.
I have Excel graphs I'd be happy to post.
Best Answer02-21-2021 21:15
02-21-2021 21:15
We believe, without any evidence, that this mystery chart (Variance), if it it goes out of range, in particular to the negative, suggests breathing issues during your sleep. For instance, perhaps apnea.
02-21-2021 21:47
02-21-2021 21:47
"Without any evidence" 😆
Best Answer02-21-2021 22:06
02-21-2021 22:06
You may want to read what Fitbit says about the SpO2.
02-21-2021 22:18
02-21-2021 22:18
Yes - I know, very little. And they discourage you from taking any meaning from what you see. But what makes this graph so special is that there are no times and no numbers, just a squiggly line. So if you were tempted to try and derive value from it, I'd remind you that nothing plus nothing still equals nothing!
All kidding aside, red / negative charting kind of sort of suggests / implies that maybe you might possibly have some sort of unspecified problem that might have some sort of connection to some unspecified bodily function!
In the real world, I have had a Versa since fall 2018, and most of that time have gotten - when lucky, partial sleep charts, seldom 3 hours worth - even if I was in bed asleep for 10 hours. They recently encouraged me to get a current model - and SURPRISE, most of the same problems exist on my new model. In about 30 hours asleep in 3 days since getting it, it has shown about 2 hours sleep total, obviously no SPO2 data provided. I've tried to tell them where to look to diagnose this, I'll try again. I'll just say that some people have higher or lower HR's when asleep, also more or less non-dominant arm movement.
02-21-2021 22:30
02-21-2021 22:30
CLARIFICATION FOR THIS ENTIRE STRING
Den in USA -- thanks for posting ......in 2019!! Your question seems as relevant today as it was then!
1. This whole thing should not be shrouded in mystery. Fitbit just caused confusion because they want to stay out of legal and FDA trouble. They should just say that!
2. We are simply trying to get the O2 level in our blood just like with an oximeter at a doctor's office. Many trusted the brand to do that for them, resulting is much disappointment!
3. Fitbit will not provide instantaneous readings. They should not IMPLY they can. It's misleading because buyers hear what they want to hear.
4. The closest to a real O2 reading is an overnight reading on the watch face made available for a number of devices over the last few months. In my case (versa2), If I remember to apply the O2 watch face at night, I get intelligent readings an hour or so after getting up. The readings are 93-99% with overnight low and high ranges recorded during the night. A typical reading might be 96% average with a low of 93% and a high of 98%. That makes some sense!
5. I have not been able to download that daily data. The CS reps are unable to help, so I simple write the three numbers down each day and revert to a more usable watch face.
6. Separate from that is the data that shows up on the cell phone app. It does NOT give you O2 readings, but shows a "variability" graph. Fitbit claims if there is high variability and crosses an upper bar, there is a probability of sleep apnea. Most reports I've read that actually compared those implications to a medical device say that it does not work.
7. If you do a download of all your personal data from the desktop site (allowed once every 24 hours), you can eventually find a spreadsheet with an "infrared to red signal ratio" taken every minute or so during the night. Maybe half the readings are zero, and the rest bounce around between +100 and -100. I haven't bothered doing any statistics on this, since I have no idea what it is supposed to indicate and how it relates to the "variability" graph displayed on the cell app under your sleeping pattern (referenced in #6 above).
To sum it up:
- there is no instantaneous O2 function like a real oximeter
- there is an all night average with highs and lows if you use the new watch face
- there are two sets of data claiming O2 "variability." One has a nice graph, but is probably inaccurate. The other is very detailed, but no one at Fitbit is willing (or able?) to explain what it means or why it could be useful.
I would be very happy to share comments, data or graphs to shed some additional light on this.
To Fitbit: A job NOT well done. Your customers should not be your guinea pigs. Please HELP!!!!
Peace,
Gerry
02-22-2021 10:03
02-22-2021 10:03
Next time your with your doctor, show him the SpO2. It will surprise you at how much info your doctor will see.
The graph was designed with the help of the medical personal.
