01-21-2019 10:51
01-21-2019 10:51
For probably the last 2-3 months since the last update, I've been receiving all notifications other than text messages. I get my call, calendar, and all app notifications, but not my texts. I have tried everything; turning off/on my phone, turning off/on my bluetooth, turning off/on notifications inside the fitbit app & in my settings for messages & fitibit, I've deleted my fitbit app and re-downloaded it - nothing has worked.
Best Answer01-21-2019 13:18
01-21-2019 13:18
@GinaMarie982 phone model and OS?
01-22-2019 08:01
01-22-2019 08:01
I have an iPhone XS and the versa fitbit
Best Answer01-22-2019 13:08
01-22-2019 13:08
@GinaMarie982 I suspected as much. I've seen some posts on the forum with the same issue. It seems related to the recent iOS update. For now, you can try this, but I'm afraid iOS users need this issue addressed with Fitbit mobile update:
If you have Wifi set up, go to Fitbit mobile app and remove it, then sync your Versa. I noticed that it causes issues for me. If you have other Bluetooth devices paired with your phone, forget them. One of them might be causing issues. Also, make sure All day sync is enabled.
I know it seems a lengthy procedure but I'd like you to start almost from scratch. Good luck.
01-28-2019 10:50
01-28-2019 10:50
I’ve tried it three times and it still isn’t working 😞
Best Answer01-28-2019 16:55
01-28-2019 16:55
@GinaMarie982 I hoped it wouldn't come to this, but I'm afraid the last thing to try is to restore Versa to factory defaults (perform a factory reset) and set it up again. This will wipe your Versa, so please sync first. You will also need to delete your tracker from the Fitbit account (in the Fitbit mobile app) and your Paired Devices list in your phone Bluetooth settings. You can perform factory reset by going to Settings on your Versa, scrolling down to About and tapping Factory Reset. Once Versa resets to factory defaults, you will need to set it up again by adding it as a new device in the Fitbit mobile app. Good luck!
01-29-2019 05:41
01-29-2019 05:41
Did all that and it’s saying I need to update it before I can use it. The update keeps failing. I’ve done this countless times for a total of maybe three hours. I don’t have time for this.
Best Answer01-29-2019 07:09
01-29-2019 07:09
Okay, FINALLY able to connect and get the update. NOTIFICATIONS ARE STILL NOT WORKING!! 😞
Best Answer01-29-2019 22:01
01-29-2019 22:01
@GinaMarie982 I'm afraid this needs to be addressed by the software update. Are you running the latest version of the app? I believe there was a new release on Jan 25 (at least for Android). After the update/installing the app, it's a good idea to reset both Fitbit app notifications (in your phone settings) and Versa notifications (in Fitbit app).
Best Answer01-30-2019 05:32
01-30-2019 05:32
Yes, says it was updated last week.
