Exercise not showing in my Dashboard-Versa
when I go to my dashboard my exercise is not listed
the watch has it but it is not on my mac
syncing issue?
also no gear icon for my run to set up gps it just says connecting
thanks in advance
Moderator edit: added label
2 REPLIES 2
Hi there @IronGirl57, welcome aboard to the Fitbit Community! I was reading your post that your exercise was not showing in your Fitbit Dashboard. In this case it might be related to syncing or just a delay to compile your information. I'm wondering how it goes so far? Is the issue still persisting?
If the exercise has not synced, try the steps of this article: Why won't my Fitbit device sync? But only try this is the issue continue.
The gear icon you are referring, is in the main menu of the exercise app. Once you have started the exercise you will not see the gear option, only the status of the Connected GPS.
See you around and hope this helps.
Roberto | Community Moderator
THANKS!!!
