Hi
My versa wasn't syncing with my Galaxy S9 so after alot of messing, I tried a factory reset. This didn't work and all I get is "Data not cleared, Sync and try again". My phone cannot connect to my watch because it says the pairing code is incorrect. I now can't get to the settings screen on the watch to redo a factory reset
Please, can anyone help???? 😞
Best AnswerThis is what my versa is showing. I have uninstalled the app but when I try to set up my versa again, I get to the bluetooth bit - the app finds my versa but says it can't pair. I now can't do anything with the versa as its stuck on this screen.
I am in the same exact position! My factory reset failed and I have the same screen showing on my watch. I cant do anything 😞
Best AnswerI think I only have two options left. Wait for the battery to run out and see if it helps or take it back to the shop.
Best AnswerHey there. Hope everyone is healthy. Did you ever find a solution for your screen with the red "x" on it?
