01-09-2019 18:27
01-09-2019 18:27
I purchased a Fitbit last month, I’ve tried contacting you and have not received a response. I am having the following issues with my device:
Best Answer01-09-2019 18:53
01-09-2019 18:53
@TeganDaisy wrote:I purchased a Fitbit last month, I’ve tried contacting you and have not received a response. I am having the following issues with my device:
- Waking up of a morning and having 300+ steps
Could it be that you get out of bed at night? I know I do and I can step a little. If you don't, then perhaps you're a restless sleeper? If you still think Versa is adding ghost steps, try changing the Wrist Placement setting to Dominant and reboot your device by pressing and holding the left and bottom right buttons until Fitbit logo flashes.
- Unable to link my card to the wallet as a wrong number is listed
For verification via SMS? Have you called your bank if perhaps they're require verification via phone? Or perhaps you need to contact your wireless provider to enable texting at this number?
- Only sometimes receiving text notifications
I was about to ask if it syncs properly but I see the answer below. It requires stable Bluetooth connection.
- Doesn’t sync to my phone
What's your phone model and OS? Also, versa firmware version and Fitbit app version?
- After being told it was made of stainless steel I find out there is nickel in the buckle and face which I am allergic to and now my skin is now peeling
Stainless steel doesn't mean nickel free. It depends on the class and grade of particular alloy. So, yes Fitbit versa is made of stainless steel but it does contain nickel. Like many other stainless steel grades.
Best Answer01-09-2019 19:28
01-09-2019 19:28
Hi
I don't get out of bed at night and even if I went to the bathroom it wouldn't be that many steps but I'll try the dominant hand setting, thanks for the tip.
I've rebooted my versa several times as that is a troubleshooting fix and has not fixed the issues of syncing or not getting messages.
I'm trying to verify it via the fitbit app that send the text but the number they are texting isn't mine and I have enabled wearables with my bank.
I have a Huawei P20 Pro with Android and my fitbit versa firmware is 32.33.1.30 and latest version of the app from 17 Dec.
I specifically asked if there was a chance of nikel being in the smartwatch because I have an allergy and was told there wasn't
Best Answer01-09-2019 20:22 - edited 01-09-2019 20:29
@TeganDaisy it seems like there's no reliable Bluetooth connection. First, try to restore it:
The trick here is to not pair in phone Bluetooth settings but rather let the Fitbit mobile app do that.
Additional tips if sync issues persist: If you have Wifi set up, go to Fitbit mobile app and remove it, then sync your Versa. I noticed that it causes issues for me. If you have other Bluetooth devices paired with your phone, forget them. One of them might be causing issues.
For the notifications, please do the following:
Regarding the allergy, the only thing that comes to my mind is getting a case for versa or a type of leather/fabric cuff band with the hole for sensor.
Best Answer01-09-2019 20:32
01-09-2019 20:32
Hi
I've tried all of that thank you but still having the issues
Best Answer01-09-2019 20:37
01-09-2019 20:37
@TeganDaisy you can try syncing with other device. If this does not help try downgrading Fitbit mobile app to version 2.74.2. this is pretty stable build that seems to work best in problematic cases. You can find APK file on the internet. You will have to uninstall your current Fitbit app and simply install 2.74.2.
