07-27-2021
19:03
20:47
07-27-2021
19:03
20:47
My Versa 3 can find my phone but with notifications turned all the way up and background app permissions given phone won't properly ring while fitbit app is running in background. I get one hard to catch high pitched beep intermittently and not the full ring
07-28-2021 06:27
07-28-2021 06:27
Hi there, @NestDani. Welcome to the Community Forums. Thanks for the details provided in your post and for checking those settings on your phone before reaching out.
Keep in mind the following requirements in order for the Find Phone app to work properly:
To find your phone:
If the issue persists, see How do I troubleshoot apps on my Fitbit device?
Hope that helps.
Best Answer07-28-2021 16:52
07-28-2021 16:52
Hi,
I've followed the troubleshooting apps instructions and app has full permission.
Watch is connected and paired with phone and is connecting with phone to find phone. Issue is that the phone will not properly make the sound it is meant to make and I cannot find it due to the quiet and intermittent beeping if the Fitbit app is only running in background.
07-28-2021 16:53
07-28-2021 16:53
@NestDani I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Best Answer04-24-2022 14:16
04-24-2022 14:16
I know this is old but was it ever resolved?
Thanks
Best Answer04-24-2022 14:18
04-24-2022 14:18
Just wondering if you ever got a solution?
It's one of my favourite features of my verses and now it's not working with my new oppo phone
04-24-2022 16:45
04-24-2022 20:30
04-24-2022 20:30
Hi @Jjjjj57 - an oppo may be a bit special and require a certain setup but a way to check is to install SimpleCheckUp app on the watch.
Then logout of the app and restart both watch and phone.
Login again and sync.
Use the app on the watch to check if the watch is connecting properly and when it last synced and it will do find the phone (if it's working) anytime you want to use find the phone.
If it says it's not connecting you will know why find the phone won't work.
Best Answer08-24-2022 13:19
08-24-2022 13:19
Same question as NestDani. I've gone thru all the tutorials, setting and resetting and still won't find my phone. Giving up, returning and getting an Apple. 🙂
