Find my phone too quiet
The find my phone feature on my versa 3 has turned into a very quiet, very brief PING rather than the super load, easy to find jarring one from before.
I have an Android. How do I fix this?
3 REPLIES 3
Hi @AnnaLeach  - have you tried restarting both watch and phone, and also check the do not disturb setting, although it should override it.
Avoid using headphones when using this function in case you damage your ears.
I've tried both, still a very quiet very brief chirp
I have the same issue on my Versa 2, with Android phone. Too quiet, and no obvious setting to change.
