06-02-2018 19:07
06-02-2018 19:07
My Versa won’t “finish” or “end” workout when I’m swim mode. What do I need to do?
Best Answer06-03-2018 05:05
06-03-2018 05:05
The sequence to finishe a swim workout is press the bottom right button. Then press the top right button, then tap the red END sign on the screen. Is this what youbare doing?
Helen | Western Australia
06-03-2018 07:24
06-03-2018 07:24
No, I haven’t been doing that at all. Instead, I’ve been trying to hit the double bar on the lower right corner of the screen to end the swim.LOL I will definitely try your suggestion next time!! Thanks!!!
Best Answer12-27-2018 22:05
12-27-2018 22:05
I have had the exact same problem with the swimming mode!!
i think the trick is unlike the other exercises on the watch is to not use it by touch screen at all ,instead
press play with the bottom right button to start. Once you have finished your swim you will need to pause it with the same button. if it is not pausing give it a quick double tap then only once it is paused you can end it .To end the exercise press the top right button same goes as before if it does not work the first time double tap it.... i hope this worked for you as it did for me
you may want to try it at home first so you can have a play around before trying it just before a swim
Best Answer06-10-2019 18:31
06-10-2019 18:31
Any recommendations on how to do this with the versa lite? There is no side button to push. It’s only a touch screen option. Thanks.
