Fit Bit Versa Special Edition Charcoal
ANSWERED
Hello -  I wondered if any one could help, I have bought a fitbit vesa, does anyone know if there are different types only the one my daughter wanted was a digital face but its been delivered and the face is showing a clock face. Is this one of the same watch but has two different faces?
1 BEST ANSWER
Accepted Solutions
Actually, @laeve there are two different Versas and there are five different bands. Click to see them
Stepping in the U.S.A. since September 2013. Android 14
3 REPLIES 3
Hi @laeve
Did you remove the sticker from the face of the Versa? Once you get set up, you'll find there are several clock faces from which to choose.
Here is the Versa user manual and related articles area - click to go there
We're here if you need us!
Thanks for the prompt response, I haven't opened it yet as was worried if its the wrong one they may not take it back.  As long as their is an option for a digital face then it should be fine. I presume there is only one versa but you can order with different straps?
