01-17-2019 01:53
01-17-2019 01:53
Hi,
my fitbit screen went all blurry yesterday and froze so I couldn't use it - then when the battery ran out I charged it but it won't turn back on 😞
01-17-2019 14:22
01-17-2019 14:22
@el94x Have you tried wiping the charging contacts with alcohol and charging from USB port on your computer? If after doing that, you still cannot boot your fitbit, I would recommend contacting Customer Support to guide you through the next steps.
02-01-2019 20:42
02-01-2019 20:42
Mine just did the same thing! I powered it off (no fitbit logo appeared) and now it won't power on.
02-01-2019 20:55
02-01-2019 20:55
@JonesLovesDogs have you tried rebooting it several times (press and hold the left and bottom right buttons until Fitbit logo appears)? If this doesn't help, try pressing all buttons for a long time (up to 3 min).
02-02-2019 18:55
02-02-2019 18:55
02-03-2019 10:44
02-03-2019 10:44
Welcome to the Fitbit Community forums @el94x and @JonesLovesDogs! Thanks for sharing the issue that you've encountered with your Fitbit not turning on again. I appreciate the details you both provided. In this kind of cases following the steps @Marrrmaduke kindly provided (cleaning contacts and restarting, may work. Please note that you have to leave the Versa charging for at least two hours.
@JonesLovesDogs I'm happy to heart that you contacted Customer Service and that they took care of you, @el94x please let me know if you were able to solve the issue or if you need me to create a case for you with our support team.
Do not hesitate to contact me if you need anything else.
