07-29-2020 07:59
07-29-2020 07:59
Hi
I have a Fitbit Versa and a LG G6 phone (Android 9).
Recently my phone battery started to drain at a rapid pace. More annoying is the fact that the phone started to slow down (slow response). I also noticed that Google Play Services consumes a considerable amount of power.
I tried to find the source of the problem and then I found out that limiting the Google services location services helps to reduce the consumption as well as restore the phones response dramatically.
However, after a few days, I entered the Fitbit App and saw that there was no sync to the watch. The message was that it required the location service to be turned on. Once I turned on the location service (for Fitbit only) - battery drains, phone slows down etc.
I don't understand what is the connection between location service (used for GPS etc - which I was not using) and watch phone sync. Any idea?
Please help as this is pretty annoying situation
One more thing, I tried to contact Fitbit directly and turns out I need to report through Twitter. Not sure why I need to open a Twitter account to report an issue (or in other words: Not all the world uses Twitter, surprise, surprise).
Hope Fitbit people read this and respond
07-29-2020 08:24
07-29-2020 08:24
Since I had an LG G6 with a Versa I am going to take a stab and say it is not the Fitbit app that is draining your battery. I would download a battery monitoring app so that you can see what is really draining your battery. There are plenty of free ones in the Play Store.
07-29-2020 09:51 - edited 07-29-2020 23:09
Hello
Thanks but, yes it is.
Again the draining is by Google play services, triggered by Fitbit App (the draining stopped when I turned off the location service of Fitbit App in Google services)
Right now it is consumed :25%
Next is whatsapp with :7%
