Fitbit OS 2.2 - Versa Firmware Release (32.12.19)
Hi, everyone! I am excited to announce the release of Fitbit OS 2.2! (Firmware Version: 32.12.19) At this time, we've released Fitbit OS 2.2 to a small group of Fitbit Ionic and Fitbit Versa users.
WHAT'S CHANGED?
Please check out this help article to see what's new in this update.
IS THIS UPDATE AVAILABLE TO ME?
This update has only been released to a small group of Fitbit Ionic and Fitbit Versa users. If you have not yet received an update notification and wish to force the update, you can give the watch a FACTORY RESET and then follow steps 1 - 4 below. Please make sure you sync the watch before performing the reset so that all your current data transfer over. Factory resetting your device clears all data from the watch including music, Fitbit Pay information, and apps. Historical Fitbit data will still be available in the Fitbit App.
HOW DO I UPDATE?
Step by step instructions for updating your Ionic can be found here. We recommend updating your Ionic over a home Wi-Fi network as this can greatly reduce the time it can take to get set up. For more information on connecting your Ionic to Wi-Fi, check out this article.
If you run into trouble updating your Ionic, please follow these steps:
  1. Restart the watch.
  2. "Remove" the watch from your account inside of the Fitbit app.
  3. "Forget" the watch from your phone's Bluetooth settings (along with any other Fitbit devices paired to your phone)
  4. Try the update again.
Looking forward to hearing everyone's feedback on the latest release. If you have questions, please let me know in this thread!
490 REPLIES 490
Is this new firmware FINALLY supporting O2 measurement ??
It was advertised it would be comming but still nothing !!
No support for 02 in this firmware. At least not in an api devs can access.
I don't get it... I posted a recommendation for a download area for patches and offended someone enough to have it removed.  So worried about a smart recommendation and not servicing this watch.
@SunsetRunner  Is this new firmware FINALLY supporting O2 measurement ?? It was advertised it would be comming but still nothing !!  No it's not. But, according to the Charge 3 forums it will go in beta-testing this month. If you see a red light on the underside of your watch, it is the SpO2 sensor, collecting data for analysis by fitbit. You don't get to see this data, but they do.  See also : https://www.fitbit.com/labs
@wiseman13No support for 02 in this firmware. At least not in an api devs can access.
That data won't be available via a public API anytime soon, that's for sure. For the rest, see comment above.
Since the update, no of my apps sync to my band.  No text messages. No weather. No email notifications.  Everything is set in the app. But I get a text message once a week. Also now this. My band shows nothing. The app shows 4K steps  image.jpg
@GeenEyedChick Can you see the stats in the Today app when you swipe up on the main Versa screen? It seems to me it is clockface fault which needs to be updated to work with a new firmware properly. Try installing an original Fitbit clockface. To resolve syncing/notification issue, try rebooting versa several times. If this doesn't help unpair Versa from your phone Bluetooth settings.
Marrrmaduke | Canada
Charge HR, Blaze, Charge 2, Charge 3, Inspire HR, Versa Lite, Versa SE, Aria
I have had posts rejected due to the accidental presence of words deemed unacceptable, when in fact the unacceptable words where just sequences of letters within other perfectly normal harmless words. In other words their automated mechanism for rejecting posts could do with some re-thinking.
Sent from Mail for Windows 10
This is now 11/11/18 and I still didn’t get the update to firmware version 32.12.19, what gives Smiley Mad
My personal experience there are QC issues that have yet to be resolved.
This is an Update to  Post 104 where my Versa was bricked after installing updated firmware then a replacement unit was sent out only this Versa had a Battery Issue and required charging twice a day. Watch Function down to only tracking steps and syncing manually with all notifications and HR turned off as per support instructions as well as charging via computer USB port and ( updated firmware again) Support was helpful however unable to solve the issue and are in the process of sending another replacement Versa (This will be number 3)
Purchased  Apple watch 4 only to return it the same day, too complicated, liked the Versa better, however, I have lost confidence in the Versa Model given my experience and  Purchased a Charge 3.
Upgraded to Versa model from a Fitbit Charge HR2 model that refused to accept a charge after 14 monthsFully Charged USB port computer time 20:30Fully Charged USB port computer time 20:30Confirmation via app Fully Charged 20:33Confirmation via app Fully Charged 20:33After 5 hours 45 minutes sync indicating Battery MediumAfter 5 hours 45 minutes sync indicating Battery MediumAfter 12 hours 30 min sync indicating battery lowAfter 12 hours 30 min sync indicating battery lowBattery Empty after 13 hours and 25 minutes. Notifications turned OFF Manual syncing and HR turned OFF.Battery Empty after 13 hours and 25 minutes. Notifications turned OFF Manual syncing and HR turned OFF.
My fitbit is still on version 32.10.15 - I've yet to get the update option?
Today is now 11/12/18 and I still didn’t get the update to firmware version 32.12.19, what gives Smiley Mad
@SunsetRunner, @Unicornpff  If you insist on forcing an installation of 32.12.19 you can do so by a factory reset, and removing your Versa from the app, then start from scratch. Note that music, wallet, custom apps all have to reinstalled. Note that some custom apps/clockfaces will not work anymore as they first have to be recompiled for SDK2.0 (ouch, so much for backward compatibility). Note that once 32.12.19 is installed, you cannot go back to .15 anymore!!!
Not sure whether the moderator has been fired or she has resigned due to your posts Smiley Very Happy
That’s not true
Have you guys tried resetting you versa? I have two fitbit versa's and after reset when I am asked to upgrade the firmware like a fresh install it upgrades to to 32.12.19.
I forced the update and wish I hadn't done it. Battery life has gone from great to bad. My versa has worked good from day one and now is glitchy. Heart rate monitor has gone nuts! When its charging the screen is all distorted! These are just a few of the bugs.....
Jaizzert I agree, it sounds similar to my experience documented here  Post 104  and here Post 309 . Now waiting for replacement Versa replacement under warranty number 3
Contact customer service as you may be eligible also for a replacement.
Purchased a Fitbit Charge 3 as l have lost faith in the Versa model.
@Jaizzert
You were 'warned', that's probably also the reason that only 10% or so has it... Smiley Sad
Some ppl seem to live ok with it though. It's unfortunate that you can't roll back, or manually force the install a previous version (as one can do with many mobile apps, for example).
Yea I know I was "warned" but its because Fitbit take so long to release updates that people go ahead and force update! Fitbit need to get their act together and stop using our watches as beta testers! I will never buy another Fitbit,as  their attitude to their customers is appalling
I've force-updated this morning, everything looks good, including battery life
