10-09-2019
15:47
11:59
AlessFitbit
10-09-2019
15:47
11:59
AlessFitbit
Fitbit Update: 10/30
Hi, Versa Smartwatches family,
We're happy to announce that Fitbit OS 4.0.2 (Firmware Version: 68.9.15) has now gone out to 100% of all users. Please download it if you haven't already.
We always recommend keeping your watch and the Fitbit app up to date on the latest versions to have the best experience.
Fitbit Update: 10/9
Hi everyone,
We’re excited to announce the release of Fitbit OS 4.0.2 (Firmware Version: 68.9.15).
We've begun releasing this new firmware to customers. This is a progressive rollout which means everyone will receive it at different stages until it has been completely released to all users. We roll out releases in phases as a cautionary measure so that we can monitor performance closely and make adjustments if needed.
*Firmware releases are not distributed based on region or location and can reach anyone no matter where you reside. We do not recommend performing a factory reset to force the update to your device as your data will be lost and you may not get the update. Please be patient and wait until you see the update banner inside of the Fitbit app to begin the firmware download.
WHAT’S NEW AND FIXED
This release includes bug fixes and improvements.
HOW DO I UPDATE?
Step by step instructions for updating your Versa can be found here.
To update Versa Lite Edition, leave on all-day sync and let the Fitbit app run in the background on your phone. When the update is ready, you’ll see a notification in the Fitbit app.
If you run into any trouble updating your Versa or Versa Lite, I recommend reviewing these troubleshooting tips.
We appreciate your patience while we work to roll this out to everyone.
Want to get more deep sleep? Join the discussion on our Sleep better forum.
10-12-2019 09:55
10-12-2019 09:55
Best Answer10-12-2019 10:21
10-12-2019 10:21
If anyone is having trouble with notifications, try removing the device from the app and then setting it up again. The only issue I had was my Versa wasn’t vibrating when I received texts, but this fixed it. Otherwise everything else works great!
10-12-2019 11:00
10-12-2019 11:00
HELP? This is an Actual Change since Fit-bit no longer syncs with IOS13 so my Notifications QUIT Working and so it wont show calls or vibrate for alerts. Several other sync issues! Help. The Versa firmware just updated and still same problem. Sometimes shows some, Intermittent then I guess?????
Best Answer10-12-2019 11:02
10-12-2019 11:02
Dont reset, Its just the new quick settings is on nightmode
Best Answer10-12-2019 11:08
10-12-2019 11:08
10-12-2019 13:04 - edited 10-12-2019 13:06
@Heygardenteache it was.... they also said it was staged roll out so i don't know what your issue is with it.
Just wait like everyone else that hasn't had it. would you rather get it today full of bugs or get it later after the first few roll outs have had the issues resolved?
jesus wept
10-12-2019 13:08
10-12-2019 13:08
ok. good to know.
don't need to repeat yourself.
ok. good to know.
Best Answer10-12-2019 14:28
10-12-2019 14:28
10-12-2019 15:22
10-12-2019 15:22
It's a tracker update. App has been updated several times. Will say 4.0.2 on app to update tracker firmware but tracker will say 68.9.15 when it's updated. BTW, mine updated fine and has been working fine: iPhone 7, Versa 1.
10-12-2019 15:54 - edited 10-12-2019 16:18
I thought I had mine working but now the notifications are off again. Cannot get the fitbit to pair with the phone or connect to the internet
Best Answer10-12-2019 18:13
10-12-2019 18:13
My heart rate is inaccurate since the update it's been saying it's beating 10 beats per minute.
Best Answer10-12-2019 18:29
10-12-2019 18:29
That’d be funny if you hadn’t paid so much for the thing!
Best Answer10-12-2019 22:52 - edited 10-13-2019 08:28
The issue has been figured out
10-13-2019 01:09
10-13-2019 01:09
Well done for sending out a bugged update...
You need to fix the music controls not staying connected in Bluetooth because you've got OFF after PAIR rather than ON! So you can connect it to your phone, then all you can do is turn it off again...
10-13-2019 05:26
10-13-2019 05:26
versa is still having problem receiving all notifications. Firmeware is update using Android 9.0.
I've done the following:
restarting my phone and versa more than 10 times
reinstalling fitbit app seems to help but after awhile, the notification stops again?
Am i the only one having this issues?😫
10-13-2019 05:37
10-13-2019 05:37
I updated to the latest firmware, which coincides with getting a new phone. My fitbit versa 2 wouldn't sync and exhausted all troubleshooting, including a factory reset as a last resort. Now, my data is gone and my fitbit won't connect to ANYTHING (neither new or old phone).
10-13-2019 05:41
10-13-2019 05:41
10-13-2019 05:52
10-13-2019 05:52
THIS! I thought I was going mad this morning when they weren’t working after I spent ages last night and though I’d finally cracked it!
10-13-2019 06:32
10-13-2019 06:32
Well...the engineers have been “working” on the elevated heart rate issue since 2018 so...yeah, Fitbit needs to get it together.
10-13-2019 06:37
10-13-2019 06:37
