07-21-2021
16:08
11:28
KateFitbit
07-21-2021
16:08
11:28
KateFitbit
Update: This has now released to 100%
We’re excited to announce that a firmware update for Versa, Versa 2, and Versa Lite will be available soon! Some of you may already have this update available - if you installed it, let us know what you think!
If you don’t see the update yet, that’s expected. Check the Fitbit app in a few days, and you’ll see a message when you can install the update. We expect everyone to receive the update in the coming weeks. We appreciate your patience while we get this update to all of our customers.
Did you know that we gradually release our updates? We do this to make sure everything is working just right for you. Sometimes we find an issue and it might take a little longer than expected for everyone to get the update. While you might see suggestions on how to “force” an update, we ask that you don’t try any of these workarounds. Most of the time the update won’t be available and you can lose data or encounter other difficulties. The best way to get the update is to be patient and wait for the update banner to appear in the Fitbit app.
WHAT’S NEW AND FIXED
You can find release notes here.
HOW DO I UPDATE?
You can find step-by-step instructions for updating your Versa, Versa 2 or Versa Lite here.
If you run into difficulty please review these troubleshooting tips.
We’re interested in hearing your feedback on this update! Let us know what you like! If you encounter unexpected behavior during or after your update, please post the details below.
08-12-2021 02:01
08-12-2021 02:01
I have read and heard so many stories of friends and family, who have had their fitbit devices killed by this update. Are you doing something about it - like pulling back the firmware update and doing a proper testing, before sending it out again? I have refrained from updating my Versa2, since it works absolutely fine, so I don't need any bug fixes. But can I completely avoid updating my Versa2? And how do I get rid of the annoying pop up reminding me of the "update from hell"?
08-12-2021 06:14
08-12-2021 06:14
Wondering if you have a plan to remedy all the problems that this update has caused your customers. My Versa was working fine until this update and now the battery runs out in less than a day.
08-12-2021 06:26
08-12-2021 06:26
Tried the so called fix multiple times. DID NOT WORK!!!!
08-12-2021 06:47
08-12-2021 06:47
I tried to avoid this @$&%^!# update as long as possible, but somehow it came through anyhow. Still collects steps, etc. all right but I can longer sync, after following all the suggestions given by customer "service". I could live with that, but the **ahem** watch is losing time. Right now it is almost 2 hours behind. USELESS!
And I see that I'm in good company.
Congratulations! With this latest update, you have killed thousands of devices.
I , for one, will never buy another Fitbit again.
Way to go!
08-12-2021 07:34
08-12-2021 07:34
After the update, I am now getting low battery warnings basically every day without designating exercise tracking the last couple days. I already had to charge often, but this is much worse since the update.
08-12-2021 08:55
08-12-2021 08:55
Since this update, my heart rate sensor is having issues even turning on. There is no green light on at all and my heart is consistently not reading. When I randomly get it working, it stops working after a couple hours. I don't know what is going on and spoke to someone with support and they couldn't give me an answer. Luckily, everything else still works, but I would really like an accurate reading for my heart rate. I've done reset and factory reset, neither which have worked.
08-12-2021 23:15
08-12-2021 23:15
Updated my Versa 2 last night and gutted to find I’ve lost all my Active Minutes, not just this week but previous weeks too. I’ve been working so hard to build them up. Wish I hadn’t updated 😕
08-13-2021 00:54
08-13-2021 00:54
The 4.2.2 update messed up the heart rate when moving on the Versa, it's even worse than the Sense.
If you have 72.1.9 on your watch and it's working reasonably, don't install any further updates in the hope of an improvement,
Unless Fitbit say specifically what has changed and you need that, avoid any upgrade in case it ruins your watch no longer under warranty, even from a fault due to an upgrade.
08-13-2021 01:03
08-13-2021 01:03
08-13-2021 03:38
08-13-2021 03:38
08-13-2021 03:50
08-13-2021 03:50
08-13-2021 05:21
08-13-2021 05:21
I updated my Fitbit with this update and now I have a screen of broken characters and lines and cannot reset. I’ve tried updating watch, phone and still nothing. Please advise how to fix this issue. Thanks
08-13-2021 05:46
08-13-2021 05:46
08-13-2021 10:20
08-13-2021 10:20
I have the original Versa, bought back in 2018. I'm having the rapid battery drain issues after the latest firmware update.
I've tried several ways to update the firmware. I'm doing the update via hard reset.
I've observed that when I updated just with Bluetooth (i.e. skip the wifi password step), battery drain issues becomes better. But not to the point of before the update. Takes lot longer ~30 min. to do the update via Bluetooth only. Everything Else seems to be OK.
FYI
Best Answer08-13-2021 10:59
08-13-2021 16:18
08-13-2021 16:18
08-15-2021 04:25
08-15-2021 04:25
So, having received my replacement Fitbit Versa 2 one week ago after my first one lasted just 33 days before crashing, I performed the update as prompted and immediately lost all my active zone data. Contacted support who made me perform a factory reset. I can no longer pair the device with my phone so now I have a second entirely defunct device in less than 2 months. I will never purchase a Fitbit again! Dreadful hardware, dreadful service!
08-15-2021 09:31
08-15-2021 09:31
I'm so glad I decided to skip the update and come here first. It better not push this down. I love my Versa.
08-15-2021 09:37
08-15-2021 09:37
After working w/support, I took the 35% off deal, got me a Versa 3...
I've had it for 3 days. Working great!
08-15-2021 11:44
08-15-2021 11:44
