04-02-2023
13:47
14:21
JuanFitbit
04-02-2023
13:47
14:21
JuanFitbit
My versa 2 is not tracking the correct distance. I walk with a group and all their watches have the same amount of mileage but mine is always way behind Eben though we walk the same distance.???
04-02-2023 14:24
04-02-2023 14:24
@dfbuser1956 , A warm welcome to the Community! Thank you for your message.
The distance is measured by multiplying your amount of steps with your stride length.
Please make sure that you input your personal data correctly ( high, age, gender, etc)
Also try to input your own stride length. How to can be found here: Can I change my stride length in my Fitbit account?
Best Answer04-21-2023 19:09
04-21-2023 19:09
My fitbit Versa 2 has seemed off lately, and my walking pace has slowed. When I measure the distance I walked the Versa 2 distance is now consistently 15% (sometimes 18% sometimes 13%, so going with 15%) lower than the actual distance. Which tracks with how much slower my fitbit says my pace is, even though it just thinks I am walking shorter distances in the same time. This started a few months ago.
04-23-2023 12:02
04-23-2023 12:02
@blakester , A warm welcome to the Community! Thank you for your message and information.
Do you use GPS while recording your activities?
Have you tried to input your own stride length? How to can be found here: Can I change my stride length in my Fitbit account?
Please make sure that you have the latest Fitbit app installed.
Best Answer04-23-2023 20:30
04-23-2023 20:30
Hello there,
my versa too also recently started to not count steps correctly. For example my friend would be 5000 steps and I’ll be 3750 when we walk same time, it just makes no sense!
also the following calculation makes zero sense: 10073 steps for it calculated as 6.78 km
10205– 5.04 km
10020– 6.9 km
10165–6.91 km
10092– 5.68km
Can please explain how is it possible?
10:57
08:32
04-24-2023
10:57
08:32
@KsLki , A warm welcome to the Community! Thank you for your message and information.
Depending on the activity recorded, your Versa 2 will use either the stride length for running or for walking. The length my vary depending if you are running or walking.
And the distance is measured (Stride length x amount of steps.)
That is why we recommend to input your own stride length, as advised on my previous post.
Best Answer04-24-2023 16:51
04-24-2023 16:51
I do have GPS on and permissions allowed. However, as I look back through how my walks have been tracked, it looks like the GPS has not been actually registering since early March. But when I check the settings, it should be.
