02-24-2020 04:23
02-24-2020 04:23
Hi,
DESPERATE for assistance please.
My Fitbit versa 2 is locked and says "unlock with phone", however I stupidly removed the device from my Fitbit account and now realised I shouldn't have as I can't re pair it as I need to be able to see the 4 digit pairing code on the screen which won't display because of the lock.
Can someone please help!
I'll be eternally grateful.
Have tried all the usual things including:
- Resetting watch my holding down button for 10 seconds
- Turning Bluetooth on and off (Bluetooth is working find and picks it up)
- Uninstalling and reinstalling Fitbit app- Trying web version
Basically, I need a way to unlock a Fitbit versa 2 WITHOUT a phone!
02-24-2020 06:21
02-24-2020 06:21
Why do people remove a locked tracker from their Fitbit account when they are told to unlock with the phone which can take as little as 15 seconds to unlock through the Fitbit app?
Why do users not set the pin for Fitbit pay only?
We now have to do a factory reset.
Hold the back button for about 8 seconds.
When the Fitbit logo disappears:
Release the button briefly (for less than 2 seconds).
Hold the button again until they feel a second, longer vibration, which indicates the factory reset.
02-24-2020 06:21
02-24-2020 06:21
03-08-2020
01:12
09:33
JuanJoFitbit
03-08-2020
01:12
09:33
JuanJoFitbit
It’s the first Fitbit I have set up so that is perhaps why I have done the things you have said “People” shouldn’t do?!
Where is the back button?
Did you manage to sort this issue out? I am in the same boat!
Moderator edit: merged reply
03-08-2020 06:54
03-08-2020 06:54
The back button is the button on the left side of the watch @Ab1e
I'm not sure which boat your in?
If the watch is still connected to your Fitbit account, then open the Fitbit app up and choose another pin code.
See the Fitbit help, link to help found below and search for lock.
Here is the link you want.
How do I unlock my Fitbit device with my phone?
If the watch has been removed, you will not be able to unlock with phone.
If you have a versa lite or a versa 2 follow the directions I posted above.
03-08-2020
09:40
09:34
JuanJoFitbit
03-08-2020
09:40
09:34
JuanJoFitbit
I have removed my Fitbit and now it is not allowing me to even add a new device (My Fitbit)
Can you help?
Many thanks,
I have removed my watch and it is not letting me now add my Fitbit (Versa2)
On my phone screen it asks to “Enter the pin on my Fitbit screen” but the Fitbit says “Unlock with phone”
Are you able to help?
Moderator edit: removed personal information
03-08-2020 09:43
03-08-2020 09:43
Sure @Ab1e which Fitbit? If you have a Versa lite or a Versa 2, see my post above. If you have a different tracker, please let me know.
By removing instead of a 30 second fix we need to do a factory reset.
03-08-2020 12:51
03-08-2020 12:51
I have tried both actions on the post and it is not letting me add my Versa 2.
i am unable to find or able to do a Factory reset?
03-08-2020 22:02
03-08-2020 22:02
@Ab1e simply scroll towards the top of the page, where as I have pointed out in my last 3 posts, you will find instructions on doing a factory reset to the Versa 2. The best thing to do is to not remove the tracker from the phone, when the tracker is telling the user to unlock with phone.
03-09-2020 00:16
03-09-2020 00:16
I have followed all steps and it is still not working.
I have removed my Fitbit, tried a factory reset and it is still not working!!!
03-09-2020 20:23
03-09-2020 20:23
The only thing left is to contact Fitbit.
If the tracker wasn't removed from the Fitbit account, it is a simply 30 second procedure to unlock with phone.
04-05-2020 10:54
04-05-2020 10:54
Actually you dont I have been trying to reset the pin for 3 days and it never connected back with the phone that's what makes some of us remove it from the account but thank you so very much for you criticism
04-05-2020 12:51
04-05-2020 12:51
@HowlerHottie you don't what?
I have purposely caused my tracker to get into this locked state and it took less than 30 seconds to unlock.
When the tracker says to use the phone, removing the tracker from the account will prohibit this possibility.
The hardware factory reset mentioned above may be done without removing the tracker from the account. This will now be your only option.
BTW: if the user sets the pin lock for Fitbit pay only, t is is less likely to happen.
04-06-2020 05:50
04-06-2020 05:50
The thing is, if you have knowledge and want to help and share cool if not don't be mean. I didn't lock mine my 8 year old son did when I took it off to wash dishes. The app never worked for me 3 days went by just trying to get the tracker to respond to the app and it wouldn't connect so things happen by not the way you play them at all. It took 3 days of me trying to get it unlock through the app that I decided to try and repair it and with no success so I took it off the app. But we are here to help each other not tear each other down. So help those who make mistakes or just don't comment!! Either way we will figure it out and your info was helpful so up to you on who you choose to be.
04-06-2020 06:21 - edited 04-06-2020 06:22
@HowlerHottie this thread has a green check mark which tells the user that the thread has an answer that will work. Scroll up to the top of the page, tfhis thread has been marked with a best answer. This best answer has the answer you are looking for.
I did not think it would be necessary to repeat. On February 24 I posted Step by Step instructions spelled out above in the best answer.
The app never worked because of an unrelated sync or connection error
04-06-2020 06:27
04-06-2020 06:27
Well thank you for reposting it was helpful so people like me don't have to waste $200 on a tracker.
04-06-2020 06:35
04-06-2020 06:35
Sorry I didn't repeat, I pointed out what the best answer is for and that the instructions to fix a locked unconnected tracker was posted 42 days ago.
05-16-2020 16:32
05-16-2020 16:32
Okay so. I ma seriously in tears eight now please someone awnser this. So I set a password on my Fitbit versa 2, so my brother wont get on it.and I took it off and my younger sibling has locked up the fitbit. I've tried holding the button for 8 sec. And realiseing for 2 sec. And it said data not cleard please try again. And my fit bit is not synced to my phone because I bought my sister a fit bit and switched accounts, and it wont let it sync PLEASE SOMEONE!! PLEASE GIVE ME AWNSERS!! IM SERIOUSLY IN TEARS!! :C
05-17-2020 14:35
05-17-2020 14:35
If your Versa 2 is still connected to your Fitbit account
Log into your Fitbit account through any phone.
Then simply change the pin through the app. It should take less than 30 seconds.
If the Versa 2 has been removed from your account, please see the accepted solution above.
06-16-2020 04:48 - edited 06-16-2020 04:49
Versa 2 locked and no longer paired with phone! Please help I've tried everything just not getting the press button for 8 seconds the lock screen icon shows not Fitbit logo
06-16-2020 06:06
06-16-2020 06:06
Has the factory reset worked? Won't work for me
