02-24-2020 04:23
02-24-2020 04:23
Hi,
DESPERATE for assistance please.
My Fitbit versa 2 is locked and says "unlock with phone", however I stupidly removed the device from my Fitbit account and now realised I shouldn't have as I can't re pair it as I need to be able to see the 4 digit pairing code on the screen which won't display because of the lock.
Can someone please help!
I'll be eternally grateful.
Have tried all the usual things including:
- Resetting watch my holding down button for 10 seconds
- Turning Bluetooth on and off (Bluetooth is working find and picks it up)
- Uninstalling and reinstalling Fitbit app- Trying web version
Basically, I need a way to unlock a Fitbit versa 2 WITHOUT a phone!
09-24-2020 04:48
09-24-2020 04:48
In the same boat... that second stronger vibration never came... I don't think that works at all.
09-24-2020 09:02 - edited 08-20-2021 06:07
I have confirmed that the below work's.
10-06-2020 08:55
10-06-2020 08:55
no
I was trying to go to exercise/weights and it would not let me. /so then I held button of watch and it is stuck. i tried to unlog etc. help
10-08-2020 03:05
10-08-2020 03:05
Please contact Fitbit, through online chat or phone.
08-20-2021 06:12
08-20-2021 06:12
Hi @Depressed same as what?
If the tracker is locked, ant the unit is no longer attached to your fitbit account. See the best answer above.
Here you will find the steps to reset the tracker.
11-13-2021 17:02
11-13-2021 17:02
Hasn’t worked for me
11-14-2021 14:11 - edited 11-14-2021 14:13
@Zoeknight is your tracker locked, and you removed the tracker from your account?
You will need to do a factory reset.
The timing of the steps are critical and you may need to try several times.
If the tracker is still connected to a fitbit account. It is as simple A's setting another passccode
01-08-2022 10:32
01-08-2022 10:32
It didn't work for me and I did evey thing in order.
03-04-2022 06:34
03-04-2022 06:34
We’re you able to fit yours?! Mines not working and it won’t do the second vibrate after I’ve held it down. 😔
03-06-2022 22:39
03-06-2022 22:39
This did not work any other suggestions please
03-07-2022 00:11
03-07-2022 00:11
Contact Support and have them walk you through the steps.
05-10-2022 12:27
05-10-2022 12:27
I’ve versa watch & desperate for assistance please
my versa watch is locked and says “unlock with phone” however i removed the device from my fitbit account and from phone and this is not even showing when i tried to connect it thru bluetooth now i realised i shouldn’t have as i can’t repaired it as i need to be able to see the 4 digit pairing code on the screen which won’t display because of the lock
05-10-2022 20:25
05-10-2022 20:25
Hello @SunsetRunner this has already been answered above., if the tracker was still connected, it takes 15 seconds to set a new pin and unlock.
Seeing that the tracker has been removed, your only choice is to do a factory reset. Do instructions, tap on the above link to the best answer from 2 years ago.
06-18-2022 12:42
06-18-2022 12:42
Hey this worked for me 🙂
Hold all 3 buttons for about 10/12 seconds
When Fitbit logo disappears quickly let go of bottom right button (it is time sensitive so be quick) continuing to hold left & top right
When device vibrates release all buttons it will then take a couple of minutes to clear device & restart
When it has come back k. Use the fit bit app to set up
06-18-2022 12:44
06-18-2022 12:44
When it has come back on Use the fit bit app to set up
06-18-2022 12:45
06-18-2022 12:45
06-18-2022 12:49
06-18-2022 12:49
Hi Rich, as you see this factory reset did not work for most people on this post
the steps below are how did the reset,
06-18-2022 12:55
06-18-2022 12:55
HowlerHottie … his suggestions didn’t work for me, please try mine below & hope it works, no need for the negative comments from the above guy, put me off asking xx
06-18-2022 12:55
06-18-2022 12:55
06-18-2022 13:08
06-18-2022 13:08
