02-08-2021
03:58
06:38
JuanJoFitbit
02-08-2021
03:58
06:38
JuanJoFitbit
My fitbit Versa lite wint come on for about 2 days now, its a total black screen. Press the button down but it still wont come on. What do I do.
Best Answer02-08-2021 04:48
02-08-2021 04:48
Have you made sure it is charged?
Did you do any troubleshooting for a problem prior to this?
Was it working fine a few days ago?
Best Answer02-08-2021 07:06
02-08-2021 07:06
Yes it was charged a 100% as at friday, tried ti charge it wont charge. I didnt try trouble shooting, just noticed the screen wont come up, when I lift my hand.
Best Answer02-08-2021 07:20
02-08-2021 07:20
It could be flat by now and switched off. Instructions to start your watch.
Best Answer02-08-2021 08:52
02-08-2021 08:52
Had the same issue with my first one ,so it was replaced and a year later the new on doesn't hold a charge longer then 2 and half days when it was lasting up to 5 days. Time to get it replacement
Best Answer02-08-2021 10:12
02-08-2021 10:12
Seems the battery problem is a common issue. Possibly due to a recent update, if it was working before.
In which case its probably best to inform Fitbit Support directly. They may be able to help you.
