12-01-2018 11:23
12-01-2018 11:23
I got one side of the versa band off with no problem, the other side I can't get it. The pin moves but the band does not budge......help!
12-02-2018 05:02
12-02-2018 05:02
@Chels2212 Welcome to the Fitbit Community! I hope you're doing well! Sorry to hear that you can't remove your Versa's band. Try applying some force with tweezers or a flat hear screwdriver (just a small amount of force) and see if this helps removing the band.
Let me know how it goes!
Best Answer09-10-2019 11:11
09-10-2019 11:11
I've got this issue. One side, the band can come off just fine, but the other side doesn't come off at all. I can see the pin move a little bit but the band won't budge at all...
