05-22-2018
05:02
08:33
AlejandraFitbit
05-22-2018
05:02
08:33
AlejandraFitbit
Hello,
I bought the Fitbit Versa a couple of weeks ago, and love the way it works! But, it seems it isn't doing a very good job at measuring distances, which I think is one of the main features an activity tracker is supposed to be flawless at.
I've compared the distance of a run I do regularly on a couple of devices and apps: Apple Watch, Geonaute GPS tracker, Fitbit Charge HR (connected GPS), several iPhones, Samsung Galaxy S9, apps like Strava, Runkeeper, Nike +, Google fit. They all seem to have more or less the same distance at the end of the run, which is: 6.8 - 6.9km. This is more or less correct, as the measured track is 1800m long (I run 3 laps = 5400m) and I have to run an additional 2x725m (1450m) to go to the track and get back home.
Today I did another run with the Fitbit Versa. And it measured only 5,86km. Which is more then 13% off... Meanwhile I tracked the same run with Strava on my Samsung, which is using the same GPS: 6,8km. You offer a close collab with Strava, but why aren't the distances in sync? And even more, when I do the same run with the Versa a couple of times, the distances aren't the same. For example: I did the same run last week with the Versa: 6,36km. How do you explain this? My tracking apps don't seem to have any problems with locating the GPS signal or staying connected. My Phone is in my pocket which is about 0-50cm from the Versa, bluetooth is on. Connected GPS is on and working fine the whole time. The run is also showing up on the map in my fitbit app correctly, but the distance is way off. To me this seems to be a software issue, which should be easily resolved in another software updated. Please fix this issue asap! If my old Fitbit Charge HR was able track the distance correctly via the fitbit app, why isn't the Versa?
Thx
Raf
Moderator edit: subject and format
05-31-2020 02:00
05-31-2020 02:00
@parker7887Well its GPS does also work as expected if you dont have your phone too, I was just pointing out that even with GPS on a watch it still may not help this issue with Fitbirt if their codin is the problem. BTW if I didn't want a more smartwatch-y device then a Garmin would be my choice for sure!
Best Answer05-31-2020 02:57
05-31-2020 02:57
05-31-2020 10:53
05-31-2020 10:53
Best Answer05-31-2020 11:56
05-31-2020 11:56
Hi! Me and my partner are both Fitbit users. I have Charge 3 SE and he has Versa 2. We go on walks together, but his mileage is way off the reality, even though it obviously tracks the walk correctly - the map is exactly the same to mine, but his fitbit says he walked about a mile less than me. Is there any setting that we need to check?
05-31-2020 12:08
05-31-2020 12:08
Best Answer05-31-2020 12:20
05-31-2020 12:20
05-31-2020 12:46
05-31-2020 12:46
Best Answer05-31-2020 12:55
05-31-2020 12:55
Best Answer05-31-2020 14:58
05-31-2020 14:58
Best Answer06-01-2020 23:43
06-01-2020 23:43
Quick update:
Day 4 - (Week 7 run 1 of Couch to 5k) - Exactly the same route again.
5708 steps, 39 minutes, 4.99km (actually accurate for a change).
Best Answer06-02-2020 00:01
06-02-2020 00:01
Hello,
There is another thread on inaccurate distances, fitbit are asking for info. Which I think is the most engagement with this problem I have seen from fitbit. Its here if you want to give them the info they are asking for:
https://community.fitbit.com/t5/Versa-Smartwatches/GPS-accuracy-during-exercise/m-p/4283131#M190907
06-02-2020 03:24
06-02-2020 03:24
Best Answer06-10-2020 15:27
06-10-2020 15:27
The fitbit app shows the route accurately. The google location timeline shows identical route.
Fitbit distance 12.5km. Google distance 17km
06-11-2020 00:26
06-11-2020 00:26
Unfortunately I managed to injure my knee after my last run and have been resting it since then. 1 week off and then using an elliptical to keep up my fitness level. I may well go back to running again in a week or so but I want to make sure that me knee is full healed before I run again
Best Answer06-17-2020 04:21
06-17-2020 04:21
My Fitbit blaze is fantastic when I run but my Fitbit Versa is almost a km out on a 5km run?
I literally have to change out my versa for my blaze when I run
And how do I stop my versa from counting steps when I drive?
I did 10,000 steps driving 600km the other day?
Why is the blaze better?
Thought they would be the same?
Best Answer06-18-2020 11:20
06-18-2020 11:20
06-18-2020 14:03
06-18-2020 14:03
I went on a run today and now have 2 accurate readings so far with the steps I did below. If the next day I do a run and it's good then this may be the temporary fix that could help everyone till the mods say anything.
Its been mentioned before that a way to get the accuracy back was to turn off auto-stride. When I went out for my run today I turned off auto-stride but also made sure that there was nothing in the fields of the auto-stride. An error message will show at the bottom in red but just press reset. Once I made sure the fields were blank I synced my watch to make sure that there was no data on the watch that could reference the auto-stride during the run.
Give it a shot and see if it helps. 2 in a row doing that and so far so good. Hopefully the mods will chime in soon with an update.
Best Answer06-18-2020 19:17
06-18-2020 19:17
06-18-2020 20:10
06-18-2020 20:10
Best Answer06-29-2020 17:10 - edited 06-29-2020 17:11
This is a versa 2.
I got a reply from Fitbit. They said i should take it up with Strava why they can report the correct distance.
Since my phone also tracks distance with google, the google distance exactly matched the Fitbit Versa 2 export TCS -> Strava -> recalculate distance, perhaps I should let google know there software is also wrong.
I'm stunned at the incompetence of Fitbit.
