Fitbit Versa drains in less than 12 hours
Hello,
bought the Versa at the local shop, new one, never used. Charged to 100%, updated firmware, all day sync is off, wake on manual, auto-brightness, notifications are on.
Went to sleep and when wake up the battery was 82% I was like ok (probably normal drain I thought)
Went to the work, in 2 hours I get a notification that the Versa will die soon, only 12% left, and in a few minutes the Versa completely died, charged again and it doesn't hold the 100% even for 8 hours by doing nothing with them. Versa (1st gen) completely new dies that fast? Battery defect? What kind of problem is this..
Regards,
Daniel
2 REPLIES 2
Hi @DanielFit  the Versa may have been new in the box, but it also sat there with a dead battery for how long? Sometimes a restart of the device helps and making sure you have all the firmware and app updates.
Stepping in the U.S.A. since September 2013. Android 14
The battery wasn't dead in the box, it had like 50%, so it was on a perfect charge while not in use, I am charing now again to 100% and will do a full factory reset with apps reinstall, will see if that helps me.
