Fitbit Versa is not notifying me of incoming calls
My Fitbit Versa is not notifying me when incoming calls are coming in or vibrating
1 REPLY 1
Hi, press and hold the left button for a few secs. You will see a screen that tells you if your screen is set to automatically or manually and also if notifications are enabled. If not, press it and they will be enabled. After that go to the settings, scroll down to notications and enable them (you can choose to disable them during the night). When you're done, reboot your watch by pressing and holding the left and right lower button untill the Fitbit logo appears and release the buttons.
