05-30-2019
17:34
16:24
DavideFitbit
05-30-2019
17:34
16:24
DavideFitbit
I am getting a replacement for my damaged Versa . So can i still use the old one as it still works so that i can keep the new one for the future?? As i dont want to bin it...
05-31-2019 05:26
05-31-2019 05:26
There was someone on the Blaze forum a while back, that got a replacement yet decided the original was good enough for a while. A year or so later when they tried the replacement, it was allegedly faulty. They were on the forum complaining Fitbit would do nothing for them. If you're getting a replacement in good faith, you should probably make sure it works. You can only have one Versa on your account at a time.
Best Answer05-31-2019 02:10
05-31-2019 02:10
Hi @Ramesh6 If you still have it, yes you can use it. But not if Support asked for it back or if they ask you to destroy it.
Helen | Western Australia
Best Answer05-31-2019 05:26
05-31-2019 05:26
