08-12-2020 03:34 - edited 08-12-2020 13:43
My daughter's Fitbit Versa smart watch will only work while it is on charge. I have shut the watch down while it is on charge as well as a factory reset. Nothing seems to be working.
Any help would be appreciated.
Bec
08-12-2020 04:38
08-12-2020 04:38
Hi @bec2802 I would suggest you contact Support and see if they can help you
Helen | Western Australia
Best Answer08-12-2020 13:44
08-12-2020 13:44
Thanks for the link. I will get in touch with them today.
Best Answer08-12-2020 14:15
08-12-2020 14:15
Please share your results! I went through the same thing and its not fixable. Hopefully yours is under warranty and they will support you with a replacement.
