01-05-2019 13:26 - last edited on 08-22-2021 19:47 by LiliyaFitbit
So I have had my Fitbit Versa since June 2018 and I've done absolutely everything with it from showering to swimming in the ocean. Everything was fine until yesterday. I went swimming and it seemed the battery died during my swim, which is normal since I forget to charge it at times, I dried it off and plugged it in to charge, it wouldn't turn on for a few hours. After a few hours it turned on but would only stay on while plugged into its charging point. If I took it out of the charger, the fitbit logo appears and I can't do anything with it .Also the battery is jumping from 99% to 26% and back. What should I do?
09-03-2019 06:32
09-03-2019 06:32
I have been told that you can’t get a replacement Versa from Fitbit anymore as it’s discontinued and being replaced by the Versa 2. If you are given a discount it will be on all the other models. No discount will be given on the Versa 2.
Best Answer09-15-2019 15:09
09-15-2019 15:09
Hi. I just claimed warranty for the second time for my Fitbit Versa due to this issue. I hope that this time it will last longer. I really like the watch but I have had two of them die on me while swimming without any prior damage.
Best Answer09-15-2019 23:21
09-15-2019 23:21
Good day I have exactly the same problem with my Fitbit Versa as Natz0808 please assist me to get this sorted out
Thank you
Best Answer10-02-2019 09:31
10-02-2019 09:31
I’ve just discovered I have water damage to my versa also. It is not a lite either. It shouldn’t be getting wet inside. What should I do?
Best Answer10-02-2019 16:08
10-02-2019 16:08
Best Answer11-10-2019 19:40
11-10-2019 19:40
I have a Versa and had no problems with it at all in water until this week. I was in the ocean and came out only to look down and see the entire face hanging out. It was being held together by a few wires. I didn't hit it on anything and had worn it in the ocean on previous occasions. Do I have any options if it is out of the 1 year warranty?
Best Answer11-10-2019 20:33
11-10-2019 20:33
09:08
05:17
JuanJoFitbit
11-11-2019
09:08
05:17
JuanJoFitbit
Thank you. My husband bought it directly from Fitbit. Hopefully they will replace it.
I did contact support. They sent a replacement and I received it yesterday. Although it is a different color than I had requested on the replacement form, I am glad they replaced it so quickly. I will not be wearing it in the ocean again!! Thank you for your advice.
Moderator edit: merged reply
Best Answer11-16-2019 15:46
11-16-2019 15:46
Best Answer11-16-2019 17:00
11-16-2019 17:00
Good point! I didn't think about it that way. Thanks!
Best Answer11-29-2019 18:02
11-29-2019 18:02
I went swimming with my Fitbit Versa, and it turned on and then two minutes later it shut off. After I charged it and it still didn’t turn on! I’ve charged it all day. What should I do?
Best Answer11-29-2019 19:01
11-29-2019 19:01
I would call Fitbit support. My issue was the watch falling apart, but they were very helpful .
Best Answer11-29-2019 20:03
11-29-2019 20:03
I have had mine for just as long. I have showered and swam with it, and sweat a lot while wearing it at the gym. I have always dried it off after each use. All of a sudden my screen started to go on the fritz and and would not turn on unless it was on the charger. Of course the answer as always is "try resetting it". Nope, no luck as it wouldn't even allow me to reset it. I asked what may be causing this and expressed some dissatisfaction. It responded with "sorry for inconvenience but we are glad you enjoy the product" wtf!?!? This is my 3rd fitbit and all 3 break apart at 18 months or less. I am disappointed.
Best Answer11-29-2019 20:37
11-29-2019 20:37
Best Answer12-24-2019 11:54
12-24-2019 11:54
If it's past warranty date than they only offer you 25% off. I just had this happen. My fitbit appeared to have gotten waterlogged and the warranty ended that June as well. They offered me 25% off. At that time, Black friday sales had a better deal than the discount they provided. I downgraded to the Inspire because it was cheaper. So I still have my discount and it can ONLY be used on watches. Why would I need another watch now. Customer service is actually a bit disappointing.
Best Answer02-23-2020 19:10
02-23-2020 19:10
Did you find a solution or a better waterproof tracker? My Versa also does after 18 months and I am extremely disappointed that this is an issue and fitbit is not addressing it.
Best Answer03-18-2020 05:30
03-18-2020 05:30
I have had my verse for quite sometime and I wore it in the pool the other day and now it doesn’t work. I can see moisture in the back of the watch through the 4 little windows. Any suggestions on what to do?
thank you in advance.
05:39
05:18
JuanJoFitbit
03-19-2020
05:39
05:18
JuanJoFitbit
I would contact Fitbit. They were helpful in trouble shooting before
determining that the damage to my watch was not able to be mitigated.
No miraculous words of wisdom here, sorry. I am just not wearing it in the water any more. You can add the activity later so that is what I am doing.
Best Answer03-31-2020 16:04
03-31-2020 16:04
I got mine as a gift. My friend bought it for me from a pawn shop. The person who pawned it reused the warranty before putting it in pawn
When I got mine, it was brand new. I could shower in it, do dishes in it, etc. the minute I went swimming, it stopped working. I tried for a week to get it to work with no avail.
I try contacting Fitbit and they said because the warranty was already used, I was SOL.
Fast forward three months later, I put it on the charger and it started working! It worked all day until I did some light dishes.
Now, it won’t turn on or charge. It was at 70% five minutes ago.
I feel like this “water resistant” idealism is a lie and a scam from Fitbit. They throw their clients new ones and say “I’m sorry” instead of being honest and loyal to their customers; the question is, why? To make more money? To make people upgrade?
Anyway, thanks Fitbit. Disappointed for a SECOND time because of your false advertisements.
:hundred_points:
Best Answer05-03-2020 21:04
05-03-2020 21:04
After 15 months no longer working, I just watered the garden with the hose
