01-07-2019
01:54
15:30
DavideFitbit
01-07-2019
01:54
15:30
DavideFitbit
My Fitbit will not restore to it's factory settings have done over 6000 steps in my sleep!!! Have tried everything have a Samsung s8!
01-07-2019 02:16 - edited 01-07-2019 02:17
Doing a factory reset won't remove your steps as they are synced and stored on fitbit servers. So once you reset your watch and it syncs, it will download the steps again from the server.
You can try the following to see if it removes the steps.
The steps should now hopefully be removed from you account, you can now sync you watch again and they should also be removed from there
