08-06-2019
18:29
10:10
JuanJoFitbit
08-06-2019
18:29
10:10
JuanJoFitbit
My fitbit is 8 months old, and suddenly stopped tracking everything. Things I have done to trouble shoot. 3 restarts , 1 factory reset and changed 2 faces. No lights are on. What are my next steps? Also it was a gift, who do I return to if that is my only option?
08-07-2019 00:41
08-07-2019 00:41
Hi @Sarahintheburgh I have flagged a moderator to come and help you
Helen | Western Australia
08-07-2019 08:14
08-07-2019 08:14
Thank You!
Best Answer08-07-2019 10:04
08-07-2019 10:04
@Sarahintheburgh it's great to see you in our Fitbit Community! Since your Versa is still unable to track your heart rate and other stats even though you have tried the restart, factory reset processes and changed clock faces, I'll forward your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
Thank you for your help @NellyG.
I'll be around if more assistance is needed! ![]()
Best Answer08-07-2019 11:38
08-07-2019 11:38
I am having the same issue with my heart rate not working. I have reset it, changed clock faces , and enabled and disabled the heart rate.
Best Answer08-12-2019 09:45
08-12-2019 09:45
@KStein I'm sorry for the late response. However, since your Versa is still unable to track your heart rate even though you have restarted it, turned off and on the heart rate feature, I'd like you to try one more workaround that has been helpful.
Please try a factory reset. To do so on your device, open the Settings app > About > Factory Reset or Clear User Data. Sync your watch before this in order to avoid losing current data. Finally, make sure of the following details:
Keep me posted on the outcome! ![]()
Best Answer08-12-2019 11:23
08-12-2019 11:23
@JuanJoFitbit I have did the hard restart. I also have been wearing my fitbit the same as when it was working. It is 8 months old. It is still not working.
Best Answer08-19-2019 08:54
08-19-2019 08:54
@KStein thank you for getting back and trying the recommended troubleshooting steps. By the way, I'm sorry for the late response.
Since the issue persists, I'll send your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
Let me know if you have any questions! ![]()
Best Answer12-26-2019 13:57
12-26-2019 13:57
I'm having the same issue. My Versa 2 is not tracking my steps or heart rate!
Best Answer12-28-2019 09:16
12-28-2019 09:16
Best Answer12-28-2019 09:29
12-28-2019 09:29
