04-19-2018
23:16
04:40
AlejandraFitbit
04-19-2018
23:16
04:40
AlejandraFitbit
My Fitbit Versa was working and it just randomly turned off and will not turn back on. I have the Fitbit charging but there is no sign of it turning back on. Anyone know what is going on? This is a little frustrating since I have had it for a week.
05-18-2019 08:33
05-18-2019 08:33
I received the Versa a year ago for Mother's Day.
I have had to have it replaced twice!
Currently, it is NOT updating any of my tracking info to the app.
Good luck to you.
Best Answer05-18-2019 15:14
05-18-2019 15:14
Best Answer05-25-2019 20:49
05-25-2019 20:49
Hello it’s been a few days and my Fitbit verse will not turn on. All these forums keep talking about a bottom button to press on the back but I do not see any button on the back side that I can press. I’ve tried going to my Fitbit app to try to update my Fitbit but that doesn’t work either. Please help!
Best Answer06-20-2019 18:38
06-20-2019 18:38
Hi. Still it does not open. When I charge it too, it just heats up. The customer service gave me a link to a sase but I missed the window so am asking for it again. I have living without it and not being able to monitor my ptriathlon progression.
06-24-2019 14:58
06-24-2019 14:58
Hi,
My Fitbit Versi also will not turn on. I have tried restarting it as per your instructions but nothing happened. I also checked my clock face but I am using a FitBit one. The device is not out of battery as far as I can tell, but my phone can’t “find” it to sync. I have it sitting in the charging cradle but it’s not doing anything.
Best Answer06-24-2019 16:41
06-24-2019 16:41
This is Dann Cucuta again with a new update. I will now be having my FOURTH replacement Fitbit Versa sent to me. My third one just went on the fritz as well. This time it just started vibrating on my wrist nonstop out of nowhere and would not quit. This happened right as I was about to leave the locker room to begin my workout. Now this will be the third time this has happened in six months and I've gotta say this can't be coincidence. I'm very careful with it to make sure I don't damage it and don't even get it wet, even though I'm supposed to be able to swim with it. Of course the support rep says there is no known issue with these Versa models going out like that, but c'mon people. It's happened to me three times in six months and it's obviously happened to other people in this forum. I also asked if they've been sending me refurbished models as replacements and the rep said they have only sent new ones. This is a major inconvenience that one shouldn't have to go through MULTIPLE TIMES when buying a $200+ smart watch. Fitbit should be ashamed of putting this garbage out.
06-27-2019 12:17
06-27-2019 12:17
Mine literally just now turned off on my lunch break. Nothing will bring it to life - Not even holding all three buttons for over 3 minutes (one solution). Fingers hurt now... Guess this a hint to go get that Garmin Fenix I've been eyeing...
07-15-2019 12:14
07-15-2019 12:14
my fitbit versa got very hot while charging and will not turn back on
Best Answer07-16-2019 05:40
07-16-2019 05:40
I asked Fitbit for help at https://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs and I live chatted with someone who gave me instructions on how to fix it. Eventually, after exhausting all the steps to revive my Versa, it came down to sending me a new one. I had to send to them the broken one without the straps and the turn around time of getting a new one was almost 2 weeks. I hope this helps all of you who come here to comment "same thing happened to me!"
07-16-2019 05:40
Best Answer07-16-2019 13:24
07-16-2019 13:24
The same thing happened to me. I put my watch on charging at night and next day morning, the device was warm and screen was dark. I tried to restart, cleaned the back of the watch but nothing worked. It was 5 days before my warranty expires. I was busy and couldn't reached out to Customer care earlier. I reached to them 20 days after this issue. By then, my warranty expired and they didn't offer me any replacement. They did offer me 50% discount on selected products but I don't want to spend another $100-150 to get a new watch. I wish they had some service center where they could repair it. I'll have to depart from my fitbit Versa and I would no longer be using any fitbit products.
Best Answer07-18-2019 14:40
07-18-2019 14:40
Hi...Thanks for your suggestion. It was the clock face that I had that was giving the problem. I switched back to the original and so far it hasn't gone off. But I have lost part of my today's data. Seems like the clock face developers have hidden "Trial Period".
Best Answer07-25-2019 21:47
07-25-2019 21:47
Last nite my fitbit vers battery was low so I had kept it for charge... But now it is not getting on... I have just got this 15 days back..
Best Answer07-26-2019 13:30
07-26-2019 13:30
Don't know what happened but mine started working. However, its intermittent. Dies within hours without charging. At times does not sync. I think the issue here is with its battery. I am in correspondence with Fitbit to get a replacement.
Best Answer08-07-2019 18:10
08-07-2019 18:10
I am experiencing a similar issue to many of these posts. My Fitbit app shows that my Fitbit Versa is charged. However, it won't turn on. Like others have reported, it started to lose its charge leading up to this issue. The last time I took it off of the charger, it was hot. I have tried to reset it but that did not work. Does anyone else have any new suggestions? I have tried all listed in this forum. Thank you!
Best Answer08-07-2019 19:13
08-07-2019 19:13
Best Answer08-08-2019 03:14
08-08-2019 03:14
Best Answer08-12-2019 16:20
08-12-2019 16:20
I left my versa lying in my car for a week or so in a disappointment and then charged it again and miraculously it started working and hasn't gone off for the last two weeks. Fingers crossed,that it does not decide to go to sleep again.
Best Answer08-14-2019 00:35
08-14-2019 00:35
Hi I am asking how do you turn fitbit versa lite on as you are aware it only has 1 button and I have been pressing down on the button for ten seconds and nothing also sliding across the face of the watch nothing, put it back on the charger just in case not fully charged nothing I am losing the will to live with it it keeps flashing insert the app which I have on phone tablet as well I know and understand you may think what a idiot but I don't know what else to do as I have said 1 button
Thank you who ever answers my request
Best Answer08-14-2019 01:06
08-14-2019 01:06
So my Versa just stopped working after I used it for like 2 or 3 months. I put it to charge but then it started flashing the logo on and off. What do I do
