04-19-2018
23:16
04:40
AlejandraFitbit
04-19-2018
23:16
04:40
AlejandraFitbit
My Fitbit Versa was working and it just randomly turned off and will not turn back on. I have the Fitbit charging but there is no sign of it turning back on. Anyone know what is going on? This is a little frustrating since I have had it for a week.
02-07-2019 22:44
02-07-2019 22:44
08:45
10:56
02-08-2019
08:45
10:56
Hey guys, welcome aboard!
@ronrof, I just want to make sure that you are following the correct restart process. On the Versa itself:
If the issue persists, let me know, and I will continue assisting you.
@ArgiCL, Thanks for the update. Let me know the outcome. In the meantime, I will really appreciate your patience.
Keep me posted!
Best Answer02-10-2019 02:43
02-10-2019 02:43
Still unable to use my Fitbit. It's completely dead, nothing is reviving it back. Tried charging the device, holding the left button for more than 10secs. It's not using a 3rd party watch face.. what must I do? Looks like this issue is not resolved for anyone though the moderator keeps saying issue is resolved.
Best Answer02-10-2019 04:11
02-10-2019 04:11
I found a solution u must plug it into a computer
05:24
10:56
02-11-2019
05:24
10:56
@Vedoos, thanks for troubleshooting your Versa to make it work. Since the issue persists, I have escalated your case with our Support team so they can further assist you. Please keep an eye on your inbox.
@Bdhdnxxhxksbows, thanks for the tip my friend!
Let me know how it goes!
Best Answer02-11-2019 05:55
02-11-2019 05:55
My fitbit is not turning on and I have pressed the side left button and bottom right side button. please advise what to do.
Best Answer02-24-2019 06:17
02-24-2019 06:17
You can't change the clock face if you can't get it to turn on and I also have the problem with a box coming up saying cannot connect to versa thst just keeps flashing. First I need to get it turned on to do anything and I am a techie and no matter what I do it won't turn on
Best Answer02-24-2019 07:22
02-24-2019 07:22
10:27
10:56
02-25-2019
10:27
10:56
Hello guys, I hope you are doing fine!
@ClaraC1950, Thank you so much for the update. Sounds great that our Support team has replaced your Versa. If you have further questions or comments, please let me know!
@ronrof, have you get in touch with our Support team? If so, what was their response?
@Charliangel923, I appreciate you have tried to fix this issue with your Versa. Since it's display still not working, I have escalated this case on your behalf with our Support team.
Let me know if you have further questions!
Best Answer04-02-2019 15:18
04-02-2019 15:18
I have tried this with my Fitbit verse and it hasn’t worked is there anything else I can try please?
Best Answer04-02-2019 16:08
04-02-2019 16:08
I called Fitbit and emailed pictures of my versa. They replaced it.
Best Answer04-10-2019 04:28 - edited 04-10-2019 04:36
I tried going to Clock Faces but it kept giving me this error: "Unable to connect to Versa" even though it is nearby on the charging dock.
Best Answer04-10-2019 04:40
04-10-2019 04:40
Best Answer04-10-2019 08:16
04-10-2019 08:16
Best Answer04-10-2019 09:41 - edited 04-10-2019 09:56
Some thing just happened to me today. I have the Versa since june 2018 and it always worked flawessly. The batery still lasts 4 days no problems at all..... today with more or less 60% batery the screen just stoped turning on.... the light senssors in the back are still working, but the screen wont turn on.
I tryied all the reset and hard reset methods.... but nothing works and the screen is dead.
04-10-2019 10:36
04-10-2019 10:36
Same thing happened to me!
Best Answer04-10-2019 14:32
04-10-2019 14:32
I had a similar problem with my first versa but I had a tiny crack on the lower part of the screen so it probably got water damage 😂
Best Answer04-14-2019 23:09
04-14-2019 23:09
I tried that but it didn't work. Please help!
05:43
05:09
JuanJoFitbit
04-26-2019
05:43
05:09
JuanJoFitbit
I'm currently going through the same problem with MY SECOND Fitbit
Sorry, I hit post button by mistake. I'm currently going through the same thing with my SECOND Fitbit Versa. The first one happened the day after I wore it while hitting the heavy bag at the gym. I even checked beforehand to make sure that was OK and saw that it was. Next day it was off and I thought the battery just died. It never recharged. I went through all the steps with an agent to try and reset it with no luck. At that point I only had it for about a month. They sent me a replacement, now just a few days ago, the second one is doing the same thing only a couple months after receiving it. It started with the heart rate monitor not working. Then it started randomly activating the wrong security pin while it was still on my wrist. It did it rapidly until it locked my watch and required me to unlock it from my phone, which was also a task in itself. An agent tried to walk me through the reset again, but again to no avail. So now they're sending me a third one to replace it. This is not a good look for a $200+ smart watch. I have a feeling there's something deeper going on here that their higher ups know about. They've sent me both replacements without even verifying my receipt info. Just my phone number. I love using this watch but it's been a horrible experience with these issues so far.
Moderator edit: merged reply
Best Answer05-18-2019 07:50
05-18-2019 07:50
I have the same issue, did you fix it yet? Thanks
