04-19-2018 23:16 - last edited on 04-20-2018 04:40 by AlejandraFitbit
My Fitbit Versa was working and it just randomly turned off and will not turn back on. I have the Fitbit charging but there is no sign of it turning back on. Anyone know what is going on? This is a little frustrating since I have had it for a week.
05-02-2020 11:47
05-02-2020 11:47
Hi,
I know that i am commenting on an old post - but the restart recommendation you gave actually worked!
- my display was BLANK - like it had NO power
- connecting it to charger - did not indicate it was charging - has been on charger for 2 days
- verified 5 volts on pins of charger with multi-meter
- even though it appeared to be DEAD - I performed your reset used back (left) and (right) lower buttons and the Fitbit icon appeared!!!
- once it booted up the 3rd party display showed 4% battery level
- i put it back on the charger and as i am writing this post - it is up to 33%!!! YAY!
Thank you!
Kerry
05-02-2020 12:27
05-02-2020 12:27
05-02-2020 15:43
05-02-2020 15:43
05-03-2020 00:11
05-03-2020 00:11
I’ve just had replacement Fitbit versa number 3 in the space of 12 months, each has had a different problem.
1)wouldn’t turn on and when it did the screen dulled and you couldn’t even see it
2)the screen literally came detached after I had it for 3 months, and it had no damage on it
3)only had it for 6 months, and the battery life deteriorated very quickly, considering it should last up to 5 days. I charged it too 100% and went for a bike ride 4 miles in it had died.
05-03-2020 07:51
05-03-2020 07:51
I'm on #3 as well! I'm not purchasing another fitbit from them. Its pathetic and the customer service has went down hill. I'm so disappointed after being a customer for so long... I was doing my best to be optimistic.
05-12-2020 19:16
05-12-2020 19:16
Ive tried the reset,tried charging it for 8 hours. Contacted FitBit and they offered me 25 percent off of another Fitbit product. I also had the blaze and it did the same thing. Why would I spend over 200 dollars for a new one when it's going to do the same thing
05-12-2020 19:28
05-12-2020 19:28
I am having same problem. I did the reset and the Fitbit icon showed then goes back to a backlit screen. Please advise.
05-12-2020 23:52
05-12-2020 23:52
05-13-2020 00:36
05-13-2020 00:36
05-13-2020 00:37
05-13-2020 00:37
05-13-2020 09:08 - last edited on 07-05-2020 20:00 by LiliyaFitbit
Thank you
06-28-2020 08:38
06-28-2020 08:38
Hi this method does not work for me. I left my fitbit on the charger overnight and I can tell it is warm from charging but I still cannot get to turn on.
Please advise
06-28-2020 09:32
06-28-2020 09:32
07-05-2020 10:31
07-05-2020 10:31
It don’t work with mine!
07-13-2020 08:06
07-13-2020 08:06
@AnaMadalina @Joebin Welcome to the Fitbit Community!
Let me help you with your Versa not working and thank you for troubleshooting this issue. @Joebin I have created a ticket so our Support team can further assist you.
@AnaMadalina I noticed that you already have a ticket with them so keep working with the team to find a solution.
@Llaurennhh thank you for your help here.
Let me know how it goes.
07-21-2020 01:03
07-21-2020 01:03
Did you ever get a solution??
07-21-2020 02:09 - last edited on 10-06-2021 06:09 by JuanJoFitbit
Yes i got your 25% for a new watch!But no thank you!I just wanted to fix my old watch...that you are not able to do so...so not worthy to buy a watch that cost a lot and brakes afte the warranty if over and you just want us to buy another one!Is a big No!Not worthy!
I was referring at them...the Fitbit team or whoever is trying to sell us more watches and not fix the ones we have.
Sent from my iPhone
Moderator edit: merged reply
07-21-2020 06:56
07-21-2020 06:56
I eventually was sent a comp replacement which was the wrong one. Then sent it back and received the correct one. Its such a hassle.
07-21-2020 12:20
07-21-2020 12:20
The only solution I found was to buy a new one. Fitbit offered me 30% off of a new one, but I went to WalMart and got one cheaper than their 30% off
07-21-2020 20:31
07-21-2020 20:31
You might be interested in this. They see parts and can do repairs. Check out.
https://www.joesge.com/products/fitbit-versa-fb504-smartwatch-screen-battery-board-parts
