04-19-2018
23:16
04:40
AlejandraFitbit
04-19-2018
23:16
04:40
AlejandraFitbit
My Fitbit Versa was working and it just randomly turned off and will not turn back on. I have the Fitbit charging but there is no sign of it turning back on. Anyone know what is going on? This is a little frustrating since I have had it for a week.
07-25-2020 12:39
07-25-2020 12:39
07-27-2020 00:55
07-27-2020 00:55
07-30-2020 23:01
07-30-2020 23:01
I tried the reset and my Versa will not turn on at all. On my iPhone it says the battery is full. But the Versa will no go on at all.
10-14-2020 03:42
10-14-2020 03:42
My Fitbit versa won’t turn on
10-14-2020
08:12
08:07
10-14-2020
08:12
08:07
@Shellbell80 Welcome to the Fitbit Community!
Let me help you with your unresponsive Versa. You don't mention any troubleshoots so I suggest you try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. You can follow these instructions to help your device charge.
Let me know how it goes.
10-14-2020 09:20
10-14-2020 09:20
10-14-2020
10:17
08:07
10-14-2020
10:17
08:07
@Shellbell80 thank you for the update and thank you for taking the time to charging it.
I noticed that you already have a ticket with our Support team so keep working with them to find a solution.
Keep me posted.
10-14-2020 12:12
10-14-2020 12:12
So my versa 2 just randomly stopped working & the Fitbit app says it can’t find the device to connect. Please advise. Battery is charged.
10-14-2020 12:19
10-14-2020 12:19
Thank you l, Yes it couldn’t be fixed so a new one has been ordered as still within 2 year warranty.
10-20-2020 01:39
10-20-2020 01:39
I have the same issue I have this Versa Lite a birthday presents from my husband. Had it for 3 months now the problem is there’s no screen display it’s just started being battery low all the time and now even if I charged no screen display. So frustrating!
02-09-2021 09:02
02-09-2021 09:02
Yup me to. It has always started after being wet. I took it in a hot tub for and then took it off after a few minutes. It worked then turned off and will not show any signs of life. And of course I have had it longer then the warranty.
10-05-2021 13:15
10-05-2021 13:15
Hi
I have had my fitbit for almost a year and it also randomly stopped working I can't seem to restart it or factory reset it what should I do?
10-05-2021
13:27
08:05
10-05-2021
13:27
08:05
Welcome to the Fitbit Community, @Petra.R.
Thanks for the details about your unresponsive Versa and for trying to reset it. I recommend you to try the troubleshooting steps from this help article to bring your watch back to life.
Hope it helps!
10-05-2021 14:40
10-05-2021 14:40
Hi
Thanks for your help but my Fitbit has power because it is syncing with my phone and I can see on there that it has full battery but it just wont do anything
Thanks
10-05-2021
14:51
08:05
10-05-2021
14:51
08:05
Hi, @Petra.R.
Thanks for the update. Based on your description, it could be a display issue if the watch is still syncing and tracking your data. Please try changing the clock face from the Fitbit app by tapping on your profile's icon > Versa > Clock Faces.
Catch you later.
03-21-2022 12:41
03-21-2022 12:41
I am having a similar problem. I got my Fitbit versa wet (it has a broken/cracked screen) but it will now not turn on. It has been on the charger for about a day straight and it still will not turn on. I have tried every single hack and it won’t turn on. What should I do?
