04-19-2018 23:16 - last edited on 04-20-2018 04:40 by AlejandraFitbit
My Fitbit Versa was working and it just randomly turned off and will not turn back on. I have the Fitbit charging but there is no sign of it turning back on. Anyone know what is going on? This is a little frustrating since I have had it for a week.
11-29-2018 12:34 - last edited on 10-06-2021 05:04 by JuanJoFitbit
The same exact problem happened to my Fitbit Versa! I did the troubleshooting shown below for restarting and it worked - so I'm back to enjoying my Versa. Hopefully it will not happen again.
Thank you for showing how to restart the Versa. Mine stopped working and after reading your easy instructions, I'm back on. Hopefully, doesn't happen again.
Moderator edit: merged reply
11-29-2018 14:49
11-29-2018 14:49
That's great! Fingers crossed for you. Many of us had no such luck.
11-29-2018 14:50
11-29-2018 14:50
My feelings EXACTLY!
12-13-2018 10:45
12-13-2018 10:45
12-13-2018 19:29
12-13-2018 19:29
I ended up sending it back for a replacement. I gave it to my husband. I think the key is to not let it get wet.
All in all I'm still very disappointed in a product that should have performed better. This problem has been going on for quite a while.
I wish you luck.
12-13-2018 19:32
12-13-2018 19:32
12-14-2018 08:10
12-14-2018 08:10
01-04-2019 18:50
01-04-2019 18:50
I am trying to change my clock face back but it’s not letting me. It says my Fitbit is not sinked! How do I change it back?
01-11-2019 06:18 - last edited on 10-06-2021 05:05 by JuanJoFitbit
Mine had done the same thing I've had it for a few months now. I haven't changed the clock face and the back of mine is flashing red and green. I can't do anything to turn it on this morning and last night it was at 67%.
Having the same problem. It randomly shut off this morning and wont turn back on. Last night it was at 67% and now the back of it is flashing red and green. Tried restarting and syncing and nothing's happening and have not changed the clock face. It's only a few months old.
01-11-2019 09:23
01-11-2019 09:23
I called Fitbit customer service. I sent me out a new Fitbit Versa and I sent mine back to them.
01-11-2019 10:42
01-11-2019 10:42
I bought my Versa in June (2018) and I just got my 4th replacement because every one dies out. I got mine for swimming and use it for that; I originally thought that it really wasn't good for swimming. But if yours is dying without swimming, then it's not the water ruining it. Obviously it's a defective model; I bought a protection plan for 3 years and it seems like I'll be returning it every few months. How could all three of the ones die like that? I can't believe they're still selling it.
01-16-2019 13:44
01-16-2019 13:44
Hi, there. Mine too. My Fitbit versa would heat up when charging. I tried using different outlets to no available. I just got mine in July 2018. Thats just barely 5 months! Am frustrated. Cant track my run, bike and swim now.
01-18-2019 03:12
01-18-2019 03:12
Trying to change the face, now it says it cannot connect. What next?
01-18-2019 04:31
01-18-2019 04:31
I am onto my 3rd Versa since April 2018. The first failed after 6 months, the second after 3 months and this one after 2 weeks. Each time the display stops lighting up and there are no lights on the rear of the Versa. All attempts to restart using the helpline suggestions have failed. Fitbit have replaced them each time but I can only assume there is an inherent issue with the software or the hardware that Fitbit have not made public.
01-18-2019 05:19
01-18-2019 05:19
01-22-2019 00:02
01-22-2019 00:02
My versa fitbit froze, turned off and I have not been able to turn it back on. The battery was full when it turned off. I have tried holding the left bottom and right button down for more than 10 seconds and nothing happens. I tried changing the clock face, but it failed because Fitbit is off. Help please!
01-22-2019 04:08
01-22-2019 04:08
Same issue I have. did you ever get it fixed/sorted? Mine shut off and wont come on, I tried charging it and it feels warm but not coming on. What do I do?
01-22-2019 04:41
01-22-2019 04:41
01-22-2019 04:44
01-22-2019 04:44
01-22-2019 04:44
01-22-2019 04:44
I would call Fitbit support and have them try to problem solve with you. If they can't get it to work, they will have to replace it if it's in the first year of ownership. I'm on my FOURTH one; got the first in June and this keeps happening.
