03-23-2019 11:01
03-23-2019 11:01
Hi,
my Fitbit Versa won't charge past 6% (even when charging for several hours) and when unplugging from charger it drops to 5%.
I've tried to reset pushing all the buttons, tried different charger but the result is still the same - the device shows charging, but the battery status is still low.
On top of that the device's display started to suffer from "backlight bleeding" few weeks ago.
Can you offer some solution?
Thanks,
Jiri Furst
03-23-2019 11:12
03-23-2019 11:12
Hi, since you've already performed all knows solutions to solve the problem whithout any luck, contact Customer Support and ask for a battery test.
Best Answer03-23-2019 16:36
03-23-2019 16:36
@SunsetRunner Have you tried cleaning the charging contacts?
Please try the below:
We recommend occasionally:
Clean the charging contacts on the back of your device to ensure they stay bronze or gold in color:
Clean the pins on your charging cable:
Hope this helps.
let me know if you have any questions.
please mark this post as “accept as solution” if you feel that this has helped you.
Thank you,
Juliette
