Fitbit connection with one plus 6 smart phone.
ANSWERED
hi all,
im planning to buy a Fitbit Versa 2 smartwatch.
Also i have a one pus 6 smartphone.
Are there any connectivity issues between the two??
my Fitbit Blaze that i already have does not connect well with my one+6 smartphone.
HELP,
Thanks in advance,
DevD
Moderator edit: format
1 BEST ANSWER
Accepted Solutions
@fitDevD Welcome to the Fitbit Community! I hope you're doing well!
Let me help you with your syncing issues with your Blaze and phone and with your inquiry about it working with the Versa 2. Your phone doesn't show as compatible but that doesn’t mean it won’t work it just means that it hasn’t been tested by our team. You can try the following:
  • Go to your phone's bluetooth settings and remove all devices listed there.
  • Restart your phone and restart your device
  • Check that no battery saving app/feature on your phone is affecting your Fitbit app.
  • Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
  • You can find troubleshooting instructions here.
If you purchase your Versa 2 you can try it during the return window and see if this works for you.
Let me know how it goes.
Alvaro | Community Moderator
2 REPLIES 2
Hello,
I  have a One Plus 6 phone and a Fitbit Charge 3. No issues with connecting. I may upgrade in the next month to a Versa SE. Let us know if you have any problems with it.
