05-09-2019 07:36
05-09-2019 07:36
I had a Charge 2 that would lose Bluetooth connection daily. I recently bought a Versa and am still having the same issues. I have to go into my IPhone settings, turn off Bluetooth and then turn it back on every morning. Sometimes I have to do this multiple times a day. Is there a fix for this?
05-09-2019 11:11
05-09-2019 11:11
Hi, which iPhone are you using?
05-09-2019 11:16
05-09-2019 11:16
05-09-2019 11:20 - edited 05-09-2019 12:00
Hi, see this article about Bluetooth issues. The essence of this article is: do you have multiple BT enabled devices in the vicinity of your iPhone? If yes, move them out of BT range from your iPhone, preferably more than 50 feet.
05-10-2019 12:46
05-10-2019 12:46
Thanks for your reply. This is a fairly new issue, last few months or so. I don’t have any other Bluetooth devices than I did before the issue started so I have to think it’s something else.
05-10-2019 14:37
05-10-2019 14:37
I’m having the same issue. Now I can't even get it to connect to get notifications. It seems to sync the data but notifications don't come across. I've turned off and on notifications, reset Bluetooth and even forgot the device and then paired again and still won't connect....
05-10-2019 14:40
05-10-2019 14:40
Hi, I did not mean that you have a lot of BT devices in the vicinity of your Versa, but maybe your family members/friends.
