01-26-2019 16:16
01-26-2019 16:16
I have tried resetting my watch. Reset failed, your data was not cleared please try again.
01-26-2019 16:57 - edited 01-26-2019 17:00
Hi, how did your reset your Versa? By the three button method or by going to the settings of your Versa and scrolling down to Device info and scrolled down to factory reset? If in one of both cases the answer is yes, then I would advice you contact Customer Support with this issue.
01-26-2019 16:58
01-26-2019 16:58
Was it a Factory reset you tried? Try it again, but ifnit fails younwill need to contact Support (link in my signature)
FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up. Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Helen | Western Australia
