08-30-2018 21:09
08-30-2018 21:09
Whenever I go to my profile, I check to see if anything I’ve posted recently is there but it’s not. However, I do see my posts through community groups... and it’s been two weeks already. Therefore, restarting either the app or my phone is not the way to solve the problem.
08-30-2018 22:22
08-30-2018 22:22
I'm not sure what you are talking about. I assume its the community feed on the app.
If you look at Notifications you will see if there are posts after something you have posted
Wendy | CA | Moto G6 Android
08-30-2018 22:22
08-30-2018 22:22
09-23-2018 04:45
09-23-2018 04:45
Hi! I have the exact same issue you’re describing! For me it happened after I updated the app yesterday. Have you found any solution?
Best Answer10-19-2018 13:33
10-19-2018 13:33
Mostly that happens before the update.
