07-12-2023 14:04
07-12-2023 14:04
I go for a run with my watch recording.
I track it.
I've got a run with a map on my fitbit app.
It fails to upload to Strava.
I've done every suggested fix and none of them work. I even deleted my strava account and started a new one. What am I supposed to do?
07-17-2023 15:11
07-17-2023 15:11
@strava_not_work What a bummer! It's hard to find the solution here. I do have some suggestions:
Try connecting to another app like Google Fit and connect Strava via Google Fit
Or try connecting to Runkeeper or Motion or Virtuagym. If one of that works fine then there might be a problem with Stava. (see if Strava tells you it has a connection to Fitbit (or Google Fit).
